Re-Connecting Vent Hoses (1975 Z)
Danhattan
I dropped and restored the fuel tank.  It now looks great; no rust and property coated.  But to disconnect the vent hoses from the tank required the use of a long screwdriver to pry the vent hoses off the tank.  That is because the '75 Z does not have an inspection panel for easy access to the hoses.  Now how do I re-connect the vent hoses to the fuel tank?
I reconnected the hoses with the tank partially installed. They were disconnected from the vapour tank first to give some extra reach down to the tank. Then with them properly attached, I mounted the tank complete. I also had the car on the rotisserie to do this so that made a huge difference too.
Thanks!  I removed the interior panel and tail light panel.  Removed the vent tank and extended the hoses.  I am now in the process of lifting the tank while reconnecting hoses and pulling hoses.  It is a back and forth job.  But I am now having some difficulty getting the filler hose to fit snug against the tank.  Any advice on how to get enough leverage on the hose to force it into its final position?
well, that was a bear to get on. I ended up clamping a wood clamp onto the filler hose and then applying leverage behind the clamp to force the hose forward onto the tank. The Z is now all buttoned up and driving again.  Some have said that dropping the tank is not difficult.  Good for them, but this project was not an easy one for me.
  • Who's Online   1 Member, 0 Anonymous, 537 Guests (See full list)
