Posted February 18, 20187 yr comment_542653 I dropped and restored the fuel tank. It now looks great; no rust and property coated. But to disconnect the vent hoses from the tank required the use of a long screwdriver to pry the vent hoses off the tank. That is because the '75 Z does not have an inspection panel for easy access to the hoses. Now how do I re-connect the vent hoses to the fuel tank? Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/ Share on other sites More sharing options...
February 18, 20187 yr comment_542659 I reconnected the hoses with the tank partially installed. They were disconnected from the vapour tank first to give some extra reach down to the tank. Then with them properly attached, I mounted the tank complete. I also had the car on the rotisserie to do this so that made a huge difference too. Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-542659 Share on other sites More sharing options...
February 19, 20187 yr Author comment_542691 so, I am a newbie. how do I disconnect the vapor hoses from the vapor tank? Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-542691 Share on other sites More sharing options...
February 19, 20187 yr comment_542780 The vapor tank is behind the interior panel on the passenger side. The panel needs to come out and the tail light interior panel also. It should get clearer then Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-542780 Share on other sites More sharing options...
February 19, 20187 yr comment_542782 Correct. The more you can see of the hose path, the easier it will be to get some slack. Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-542782 Share on other sites More sharing options...
February 27, 20187 yr Author comment_543313 Thanks! I removed the interior panel and tail light panel. Removed the vent tank and extended the hoses. I am now in the process of lifting the tank while reconnecting hoses and pulling hoses. It is a back and forth job. But I am now having some difficulty getting the filler hose to fit snug against the tank. Any advice on how to get enough leverage on the hose to force it into its final position? Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-543313 Share on other sites More sharing options...
March 3, 20187 yr Author comment_543716 well, that was a bear to get on. I ended up clamping a wood clamp onto the filler hose and then applying leverage behind the clamp to force the hose forward onto the tank. The Z is now all buttoned up and driving again. Some have said that dropping the tank is not difficult. Good for them, but this project was not an easy one for me. Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-543716 Share on other sites More sharing options...
March 4, 20187 yr comment_543743 Glad to hear it’s in. Mine is still not assembled complete. Link to comment https://www.classiczcars.com/forums/topic/59562-re-connecting-vent-hoses-1975-z/#findComment-543743 Share on other sites More sharing options...
