I am thinking about sourcing and installing an electric fuel pump. I had one on my car at one point but it was lost in the restoration. I believe that I have found an original pumb but cannot find a bracket. Does anyone have photos of the original upgrade kit or the bracket?
7 minutes ago, duffymahoney said:
I thought it mounted to the gas tank?
I took a look under the car today and do not see any obvious mounting points. I did see two holes in the cross bar just forward of the tank and in prefect location for the pre-wiring that is in the harness.
9 hours ago, JSM said:
Exactly what I was looking for. The bracket attaches to the cross member just in front of the fuel tank. Thanks
Hopefully useful reference:
17033-E4200 Electric Fuel Pump Bracket, as used on S20-powered cars from 1969:
Mine, with NISMO-branded, Jidosha Kiki-made, Bendix-licensed pump:
Edited by HS30-H
Swapped photos
There are actually a couple of these for sale on eBay.  One with the same part number that HS30-H mentions in his post:
https://www.ebay.com/itm/Datsun-Z-fuel-pump-mount-mounting-bracket-17033-E4200-USED/382363930288?hash=item5906aa8eb0:g:zwQAAOSwkLhaG5cd&vxp=mtr
And another that is identical to the one on my late manufacture 260Z:
https://www.ebay.com/itm/77-78-Datsun-280Z-fuel-pump-bracket-OEM-used-painted-clean/382374963056?hash=item590752e770:g:RAEAAOSwHNxaTa88&vxp=mtr
Ironically both from the same seller.
Looks like Nissan changed the design of this over the years.
Mike.
