Posted March 2, 20187 yr comment_543571 RedBird (Jai) has been having intermittent starting problems for a few days. I listened to an audio. It sounded like a low battery problem. Battery is about a year old. Starter engaged and barely rolled the engine over. A couple of times it started fine. The engine starts and runs fine with a push. Today when Jai tried to start RB at the gas station, smoke came from under the hood. Inspection by someone says the wires going to the starter are burned. My long distance guess is a bare wire short circuit down by the starter. Possibly intermittently bleeding enough elec. to ground to deprive the starter. Today the wire must have welded itself to the chassis. Thoughts from the Georgia gang? Link to comment https://www.classiczcars.com/forums/topic/59622-redbirds-in-trouble/ Share on other sites More sharing options...
March 2, 20187 yr comment_543576 @SteveJ @gwri8 Possibly bad battery or starter connections? Link to comment https://www.classiczcars.com/forums/topic/59622-redbirds-in-trouble/#findComment-543576 Share on other sites More sharing options...
March 2, 20187 yr Author comment_543579 All I heard was burned wire(s). Yesterday I asked Jai to tug on both ends of both battery cables to see if any were loose. She checked the solenoid wires too. She says they're all clean and tight. She's getting it towed to Pete's shop, her older mechanic friend who's worked on RB before. I'm still leaning toward a shorted wire. I doubt it's anything too serious. Link to comment https://www.classiczcars.com/forums/topic/59622-redbirds-in-trouble/#findComment-543579 Share on other sites More sharing options...
March 2, 20187 yr Author comment_543592 Update. There are some burned wires. Don't know which ones yet. Pete has tested the starter and says it needs to be replaced. Starter is on order and Jai will have it back tomorrow. Link to comment https://www.classiczcars.com/forums/topic/59622-redbirds-in-trouble/#findComment-543592 Share on other sites More sharing options...
March 12, 20187 yr comment_544425 Have a close inspection done of the wires that go to the alternator as well. If you saw smoke chances are something there may have gotten a bit warm. Link to comment https://www.classiczcars.com/forums/topic/59622-redbirds-in-trouble/#findComment-544425 Share on other sites More sharing options...
