June 7, 20195 yr comment_577103 Ouch on 2 months! I will give Amazon a more concerted effort. Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-577103 Share on other sites More sharing options...
June 7, 20195 yr comment_577107 Ships are slowing down with the tariffs. ? Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-577107 Share on other sites More sharing options...
March 29, 20205 yr Author comment_595782 Someone copied my design and is selling it.   Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-595782 Share on other sites More sharing options...
March 29, 20205 yr comment_595783 @Suicideking Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-595783 Share on other sites More sharing options...
March 29, 20205 yr Author comment_595790 They will regret selling that cabinet. It’s a giant pile of trash. Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-595790 Share on other sites More sharing options...
March 29, 20205 yr comment_595792 Duffy, I took your advice and added a lot more air pressure, as you said, air pressure is everything, blasting now at 120psi. Also got rid of the circulation pump and put my old pool pump into service, works great. I will never sell your design?  Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-595792 Share on other sites More sharing options...
March 29, 20205 yr Author comment_595793 Just now, grannyknot said: Duffy, I took your advice and added a lot more air pressure, as you said, air pressure is everything, blasting now at 120psi. Also got rid of the circulation pump and put my old pool pump into service, works great. I will never sell your design?  I don’t care if you sell it. I’m now using a small trash can with the pump in it and I have the pressure out line split recirculating. Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-595793 Share on other sites More sharing options...
April 3, 20205 yr comment_596229 On 10/12/2018 at 3:39 PM, duffymahoney said: I got a new gun/ nozzle system. I accidentally bought two so if anyone wants one let me know. Hose is now 3/4 for the slurry pump, air is 5/8. So much much bigger. Hopefully moves a lot more slurry.   Also the nozzle tip can be changed out. It can be 4,5,6,8,10, 12 and 14mm.   I found the nozzle by doing some youtube stalking of vapor honing stuff. I kind of feel bad about it.  Quick question regarding the barb sizes here. I found this blasting gun but I am confused about the air and media fitting sizes you are using. You said you used a 3/4" hose for the media but it looks like the gun has a 3/8 NPT fitting. Looking at the pics it looks like you are using a 3/8 NPT to 1/2" barb. Air appears to be 5/16". Mind clarifying please? I'd like to duplicate your system since it produces wonderful results. Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-596229 Share on other sites More sharing options...
April 3, 20205 yr Author comment_596235 I have the unit at a local car shop, I get to use it whenever I want, they have a giant giant compressor. They use it. So I don't know the exact sizes.   I would buy the nozzle, then fit as big of a media line as you can. I think the media line is 5/8 or 3/4. But I can't remember. I did a lot of changes to the design as I went along.  Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-596235 Share on other sites More sharing options...
April 3, 20205 yr Author comment_596260 So cool Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-596260 Share on other sites More sharing options...
September 22, 20204 yr Author comment_606397 I have been working on some news mods for my rig. I also brought it home for the first time. It’s been at a buddy’s auto shop for a long time.  Mainly fresh water rinse and a access door that isn’t also the viewing. I got some new tempered glass and a stainless stand for it. Rinse is super important to keep media in the cabinet. The pump comes stock with a odd 45 degree elbow, which makes it’s hard to fit in a container, so I got a new straight one off their webpage   Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-606397 Share on other sites More sharing options...
September 22, 20204 yr comment_606407 9 hours ago, duffymahoney said: Rinse is super important to keep media in the cabinet. That's a good idea, once it dries it gets everywhere. Link to comment https://www.classiczcars.com/forums/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?&page=9#findComment-606407 Share on other sites More sharing options...
