Price Check: 280z Front hubs for $200
AlbatrossCafe
Dude locally is selling front hub assembly off a 1977 280z for $200. He says that rotors, wheel bearings, etc. are in good shape. I need them to cut for my coilover conversion so I don't care about the strut itself.
Is $200 a fair price?
https://seattle.craigslist.org/tac/pts/d/240280z-parts/6514563435.html
I saw them in the bottom left of this pic:
13 hours ago, wheee! said:
Why don’t you cut the ones that came with your car? I used my stock parts. I don’t plan on going back.
I did exactly that. Problem is, I cut them too short. i have to run car lowered 3" or more the way I cut them. I'll never make it out of my driveway at that height. The rear I can fix by adding some tubing, but the fronts I have to redo completely.
See:
oops, now I remember! I would just buy some appropriately sized tubing and weld them on to the right size. The tubing up from the hubs is just steel pipe basically. A clean cut and a solid weld is all you need. I remember seeing some sprinkler system pipe that was about the right size of the correct schedule of steel too.
Heck, you could probably just use the leftover tubing from the struts you cut!
Edited by wheee!
That is the plan for the back, but it seems there is no way to cut the adapter off the front without destroying everything with that narrow of a space right at the inside of the hub. Unfortunately, the shop did the cutting/welding for me and I didn't keep any of the leftover tube :( but it sounds like them sourcing some new stuff won't be too expensive.
I'm gonna try to haggle this guy down to $150 or so but it sounds like I shouldn't be too upset if I have to do $200.
16 hours ago, Captain Obvious said:
If you decide to completely bail on everything you have done so far and toss the parts, I might be interested in the cut down front spindles for an experiment.
I'm headed that way. I'll pick up the "new" hubs next weekend. The shop did a great job welding the original ones... they would be great for someone who wanted to lower their Z car 2.5+ inches. Just PM me with what you are thinkin'
Edited by AlbatrossCafe
