8 hours ago, Reptoid Overlords said:
I can't wait until she's a teenager
You might regret that statement, you're in the 'good old days' right now.
You're totally right. That statement was a bit sarcastic. Of course, I'll love her regardless of age, but if she's telling me to move over now, I imagine her teens will be a time of "confidence"
Sent from my [device_name] using http://Classic Zcar Club mobile
I must ask if the compression was good why pull it apart? These L motors are pretty stout. Is this more for the learning experience or were you truly concerned as it came from a parts car?
A little of both. The head is pretty dirty. I guess at the end of the day I really like knowing for certain everything's in good order. But mostly its for learning. It did sit for quite a while. As I uncover the small amount of grime that is on it I'm beginning to feel like I really could've just popped it right in something.
But there's also that satisfaction of when it fires up and you're driving it down the road knowing you had it apart, and put it back together.
It won't break the bank too bad either, buying parts over time.
  • 3 weeks later...
When it comes to things like head gaskets and rear/front seals, I feel like spending a few extra dollars is more than worth it..
Before I pull the trigger on Fel-Pro's head gasket and rear/front seals(which comes with side seals), should i stop and consider getting those directly from Nissan?
The Fel-Pro head gasket is multi layer steel, and I have their rear seal/side seal kit in my other car.  As far as i can tell it isn't hemorrhaging oil.  I lubed the outside of the seal before installation as advised in some other thread here.
It seems like the entire engine gasket set from Fel-Pro is the way to go, with maybe getting a Nissan head gasket.  Just to be safe.
Rock Auto also has a Hitachi oil pump for $40 I'll be getting.
I used the fel pro rear main and side seals on the first motor which was a 2.8, they don't leak but those side seals are crap compared to Nissan's in my opinion.  I used Nissan on the 2nd 2.4 motor.
side seals, 12289-W0400  $1.50 each from my parts guy
rear crank seal, 12279-2B500  $30 from my guy
I've got more Nissan numbers if you need them.  I went with Nissan on all the big stuff, rear main, oil pan, manifold.  But the Fel Pro kit for all the other small stuff because it's so cheap.  A lot of the parts come with their own gaskets, oil pump, water pump, timing kit.
I can't remember which head gasket I used.  I do remember it was different for the 240 compared to my 280.
Oh yeah, turbo head bolts.  9 short ones 11056-P7600 $4 each
5 long ones, 11059-P7600 $5 each.  $60 plus tax for all of them.  I can not remember if they came with washers or not, sorry.
Edited by siteunseen
Spent some time cleaning the oil pan up. It was dirtier than shown, I guess I deleted the picture of when it first came off the car. Under a layer of grime was a bit of surface rust.
Its mostly off now. Time for some paint tomorrow-ish. IMG_20180417_114942.jpgIMG_20180418_163404.jpg
