Posted March 15, 20187 yr comment_544658 Where do you like to use sealant, grease, antiseize, etc. on your Z and what brand & product name? I'll start: Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/ Share on other sites More sharing options...
March 15, 20187 yr Author comment_544659 Loctite "Thread Locker 242" aka Blue Loctite Crank Bolt Cam Sprocket Bolt Cam blocking Plate (with alignment mark) Flywheel Bolts Pressure Plate Bolts Oil pick-up bolts PCV-tube-mesh plate screws Edited April 3, 20187 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-544659 Share on other sites More sharing options...
March 15, 20187 yr Author comment_544660 Permatex Aviation Form-A-Gasket® No. 3 Sealant Liquid Timing cover to block gasket Thermostat housing to head gasket Thermostat housing to cover gasket Water pump gasket Water inlet fitting to timing cover gasket early 4 speed transmission body gaskets Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-544660 Share on other sites More sharing options...
March 15, 20187 yr Author comment_544661 Mercruiser Extreme Spline Grease Transmission spline to clutch Transmission spline to drive shaft Throw-out bearing sliding surface Edited March 15, 20187 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-544661 Share on other sites More sharing options...
April 3, 20187 yr Author comment_546553 Dry: 1. Rod Bearing back sides 2. Main bearing back sides 3. Pilot bushing back side Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546553 Share on other sites More sharing options...
April 3, 20187 yr Author comment_546555 Permatex Anaerobic Flange Sealant: Rear Main Cap base (back 25mm) Rear Main Cap side seals (top 25mm) Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546555 Share on other sites More sharing options...
April 3, 20187 yr Author comment_546558 Clevite Assembly Lube: Rocker Pivot Tops Rocker Arms (both contact surfaces and socket) Valve Tip Lash Pad (top, sides, and bottom) Cam Lobes Cam Rotating contact surfaces Cam Tower Surfaces Main Bearings (inside, and sides of thrust) Crank Rotating contact surfaces (main and rod) Rod Bearings (inside) Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546558 Share on other sites More sharing options...
April 3, 20187 yr Author comment_546559 Motor Oil Main bearing bolts Crank rod bolts Head bolts Piston Side oil holes Piston Pin Pre-lube oil passages in block Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546559 Share on other sites More sharing options...
April 3, 20187 yr Author comment_546560 Silver Spray Paint or Copper Gasket Spray Head Gasket Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546560 Share on other sites More sharing options...
April 3, 20187 yr comment_546565 What about timing components on a new build? Sent from my [device_name] using http://Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546565 Share on other sites More sharing options...
April 3, 20187 yr comment_546569 Spend a little more for a good kit than those cheap ones on ebay. My 280 has a $60 one from ebay and I got one from a Z specific online for $100. The quality difference of the parts was daylight and dark. It was a True Line? or something like that. The ebay was Chinese and the other American made. Cheap one had rough edges on the tensioner body and all black links on the chain. You could compare them on amazon and look for the higher rating. Good luck in your search. Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546569 Share on other sites More sharing options...
April 3, 20187 yr comment_546571 Good stuff. I'm probably going with the ITM timing set on Rock Auto for &50. looks like U.S./Japan and European sources. I'm taking notes on this thread as its pertinent to my situation. Well in the next few months at least. I was curious as to what lube would be recommended for the timing set once installed. If anything other than oil. Link to comment https://www.classiczcars.com/forums/topic/59701-sealant-grease-antiseize-thread/#findComment-546571 Share on other sites More sharing options...
