1973 240 Z Gas Tank Vents
That depends on what you are going to with the car now (stock vs modified) or might do later, I have always found it's better to keep your options open by putting a short piece of hose on on the pipes you are not going to use, put a plug in the end and clamp to shut them off, the next owner will appreciate it too.
  • Who's Online   1 Member, 0 Anonymous, 676 Guests (See full list)
