I had a local shop press my rear hubs together and had to take them back because the bearings weren’t seated correctly.
The idiot working on it tried to grind down the end of the spacer to make it shorter, so now the end has a gouge out of it.
Do I need to worry about this?
If so, how can I find a new one? Does anyone have one to spare?
Thanks in advance.
https://www.classiczcars.com/forums/topic/59746-need-a-rear-bearing-spacer/
Motorsport wants $50 each plus shipping.
http://www.thezstore.com/page/TZS/PROD/classic01a/23-5031R
Can anyone beat that?
 Edit: they only have the B version, so I need to find out which one I need from the shop. Actually, I need to get all my parts back and go somewhere else.
Try these guys. I don't see if its NLA.
Bay Ridge Nissan
532 65th st, Brooklyn, NY 11220
718-238-4776
parts@bayridgenissan.com
SPACER-BEARING (43090E4100)
YOUR PRICE     $12.02
Woof... If it's not one thing, it's another! Is this the same shop that bent your control arm?
All else fails, I can probably make a new spacer.  I can certainly shorten one up if you find you can get the longer length but need something shorter.
