Posted March 28, 20187 yr comment_545857 Has anyone one tried to fit v-6 ecoboost in a 240z? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/ Share on other sites More sharing options...
March 28, 20187 yr comment_545860 this guy did something similar. Can't remember the details but he had a camaro motor he was gonna swap into a Miata I think.@djwarner Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/#findComment-545860 Share on other sites More sharing options...
March 28, 20187 yr comment_545873 I acquired a Camaro 3.6L LFX engine and 6L50 AT salvaged from my wife's car after she was rear-ended. The direct injection engine is somewhat unique in that it has exhaust manifolds incorporated into the heads and simple downpipes coming out of each side. The engine puts out 323HP on regular gas and the LFX/6L50 combo weighs less than the Z engine alone. A mild tune can lay 300HP at the rear wheels. When I acquired the drive train, I had planned on installing it in 240Z or 260Z but could not find a sound shell at the time. There is gobs of room in a Z. As proof, I ended up installing them in a 2011 Miata with virtually zero firewall modification or other body welding. These engines are readily available and now stand alone wire harnesses are available from V8 Roadsters. Edited March 28, 20187 yr by djwarner Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/#findComment-545873 Share on other sites More sharing options...
March 28, 20187 yr comment_545882 I think there is some guys on Hybridz that have used that engine, http://forums.hybridz.org/ Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/#findComment-545882 Share on other sites More sharing options...
March 28, 20187 yr comment_545923 I bet that makes a Miata really fast! Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/#findComment-545923 Share on other sites More sharing options...
March 29, 20187 yr comment_545937 I’m waiting to get into the custom exhaust shop and then get the ac lines connected. Found a guy who makes custom gateways that allows the GM CANBUS talk to the Miata CANBUS to drive the OEM instrument panel. With the hood closed, it will look completely stock. Also added a 2 DIN android tablet so I can run Torque Pro. Formulas found by a Google search say it should 0-60 in around 4.0 seconds. Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/#findComment-545937 Share on other sites More sharing options...
March 29, 20187 yr comment_546028 On 3/29/2018 at 1:25 AM, djwarner said: Formulas found by a Google search say it should 0-60 in around 4.0 seconds. That's quick. Should be lots of fun... Link to comment https://www.classiczcars.com/forums/topic/59777-35-l-tt-ecoboost-swap/#findComment-546028 Share on other sites More sharing options...
