Posted March 31, 20187 yr comment_546191 From the FSM: Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/ Share on other sites More sharing options...
March 31, 20187 yr comment_546192 Well, mine was shaved. Does that count? Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546192 Share on other sites More sharing options...
March 31, 20187 yr comment_546197 I did check my vent line for stuffiness. Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546197 Share on other sites More sharing options...
March 31, 20187 yr Popular Post comment_546201 I found fur in mine, Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546201 Share on other sites More sharing options...
March 31, 20187 yr comment_546229 Also, according to the FSM I should easily be able to drive from California to New York on a tank gas. You’re welcome.Phil Smith Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546229 Share on other sites More sharing options...
March 31, 20187 yr comment_546234 View of the road ahead with a full tank of gas.Phil Smith Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546234 Share on other sites More sharing options...
March 31, 20187 yr comment_546238 Funny how the typos are. I even found them in the 89 wiring diagrams. Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546238 Share on other sites More sharing options...
March 31, 20187 yr comment_546247 I heard about some guy who torqued his cam-sprocket bolt to only 36 ft-lb. Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546247 Share on other sites More sharing options...
March 31, 20187 yr comment_546253 1 hour ago, Phil Z said: View of the road ahead with a full tank of gas. Phil Smith Riding low in the rear huh? 227 gallons is pretty heavy. Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546253 Share on other sites More sharing options...
March 31, 20187 yr comment_546254 1 hour ago, Phil Z said: View of the road ahead with a full tank of gas. Phil Smith A full tank of gas or just accelerating? Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546254 Share on other sites More sharing options...
March 31, 20187 yr comment_546261 Jet fuel... Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546261 Share on other sites More sharing options...
March 31, 20187 yr comment_546279 Rocket fuel! I'm having some right now. Link to comment https://www.classiczcars.com/forums/topic/59795-did-you-remove-the-fur-from-your-engine-on-last-rebuild/#findComment-546279 Share on other sites More sharing options...
