Posted April 4, 20187 yr comment_546610 Hi Guys this is my 1st post in the forum. I really don't have any good suggestion for my question! I decided to buy LUK clutch kit which fit to my car 1980 280ZX but the flywheel not included in the set I made a search and I didn't find good flywheel. I found aluminum light weight but my friends didn't recommend it. I found Sach flywheel which is fit to 1980 280ZX 2+2 . its different than base 280ZX what do you guys recommend? I am thinking to buy 1980 280ZX 2+2 clutch kit and flywheel and fix it to my 1980 280ZX will that work? Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/ Share on other sites More sharing options...
April 4, 20187 yr comment_546612 The coupe is 225mm, the 2+2 is 240mm. Your original flywheel is fine just take it to a machinists and have them lightened it up. You'd want to get it resurfaced at least. I have an aluminium Tilton and love it. It revs up like a motorcycle, quick. It takes a minute to get used to it but after that you won't notice the difference. By the time I get up and out of my driveway it's fine. Some people like the 240mm, more grip. But I don't have that kind of horsepower. Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546612 Share on other sites More sharing options...
April 4, 20187 yr comment_546614 If you haven't already looked into it, now might be a good time to replace the rear main oil seal, side seals, front seal, and oil pan gasket while the transmission is out of the way. Sent from my [device_name] using http://Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546614 Share on other sites More sharing options...
April 4, 20187 yr comment_546632 On 4-4-2018 at 6:45 AM, Ammkandari said: Hi Guys this is my 1st post in the forum. I really don't have any good suggestion for my question! I decided to buy LUK clutch kit which fit to my car 1980 280ZX but the flywheel not included in the set I made a search and I didn't find good flywheel. I found aluminum light weight but my friends didn't recommend it. I found Sach flywheel which is fit to 1980 280ZX 2+2 . its different than base 280ZX what do you guys recommend? I am thinking to buy 1980 280ZX 2+2 clutch kit and flywheel and fix it to my 1980 280ZX will that work? If you go with the 2+2 clutch, like I did, you will need the 2+2 flywheel. The 240mm pressure plate has 9 bolts where the 225mm has 6 bolts. If you go with the 240mm I would lighten the flywheel or go for the aluminium version. I lightened my flywheel. See attached jpeg. The blue text are the dimensions I used. Its good enough for street use. The 225mm and 240mm flywheels are the same weight, but the disc and the pressure plate for the 240mm clutch is slightly heavier. Some figures on installed load for original pressure plates: 225mm: 550kg 240mm: 780kg The advantage of the 240mm pressure plate is a lot more grip with the original OEM pedal feel. Like Cliff said, A lightened flywheel makes the engine more responsive. Probably the most bang for your buck on a standard engine. Edited April 5, 20186 yr by EuroDat Typo Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546632 Share on other sites More sharing options...
April 4, 20187 yr Author comment_546654 Thank you guys for your reply Thanks siteunseen Thanks Reptoid I will go with your advise Thanks EuroDat I have two options for the Clutch Kit Luk https://www.carid.com/luk/repset-clutch-kit-mpn-06-009.html?singleid=62632503 Exedy https://www.carid.com/1980-nissan-280zx-transmission-parts/exedy-oe-replacement-clutch-kit-160690490.html both are good price and fit for standard transmission ________ For the flywheel Spec Aluminum but the price is 387$ https://www.carid.com/spec/flywheel-aluminum-mpn-sn82a.html?singleid=79385619 is it worth that price ? I see ATP and Poineer brand https://www.carid.com/atp/flywheel-mpn-z-301.html#features https://www.autozone.com/drivetrain/flywheel-manual-transmission/pioneer-flywheel-manual-transmission/837806_563804_0 What do you recommend ? do i pay 387 for the Aluminum ? or the other brand ? Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546654 Share on other sites More sharing options...
April 4, 20187 yr comment_546657 1 hour ago, Ammkandari said: Thank you guys for your reply Thanks siteunseen Thanks Reptoid I will go with your advise Thanks EuroDat I have two options for the Clutch Kit Luk https://www.carid.com/luk/repset-clutch-kit-mpn-06-009.html?singleid=62632503 Exedy https://www.carid.com/1980-nissan-280zx-transmission-parts/exedy-oe-replacement-clutch-kit-160690490.html both are good price and fit for standard transmission ________ For the flywheel Spec Aluminum but the price is 387$ https://www.carid.com/spec/flywheel-aluminum-mpn-sn82a.html?singleid=79385619 is it worth that price ? I see ATP and Poineer brand https://www.carid.com/atp/flywheel-mpn-z-301.html#features https://www.autozone.com/drivetrain/flywheel-manual-transmission/pioneer-flywheel-manual-transmission/837806_563804_0 What do you recommend ? do i pay 387 for the Aluminum ? or the other brand ? Is there a reason for a new flywheel? The originals are fine. You could buy a 225mm or 240mm from someone on this forum for pretty cheap, probably cost more to ship it than what someone would sale you one for. Those are something I would think would be "a dime a dozen" but I've never bought one. I have a 240mm I'm gonna hang on to just in case I build my dream motor. more horsepower needs more surface area for better grip. Just curious though. You do what you want, but I don't understand? Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546657 Share on other sites More sharing options...
April 4, 20186 yr Author comment_546661 6 minutes ago, siteunseen said: Is there a reason for a new flywheel? The originals are fine. You could buy a 225mm or 240mm from someone on this forum for pretty cheap, probably cost more to ship it than what someone would sale you one for. Those are something I would think would be "a dime a dozen" but I've never bought one. I have a 240mm I'm gonna hang on to just in case I build my dream motor. more horsepower needs more surface area for better grip. Just curious though. You do what you want, but I don't understand? Siteunseen The synchro rings for 2nd and 3rd gear need to replace. that why i will change the clutch kit when the transmission is already down Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546661 Share on other sites More sharing options...
April 4, 20186 yr comment_546664 But all you need to do to your flywheel is get it cut or resurfaced like a brake rotor. I've bought many clutch kits over the years but none had a flywheel, I used the existing one. Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546664 Share on other sites More sharing options...
April 4, 20186 yr comment_546665 There are still automotive machine shops around that will resurface a flywheel, for about $50. You probably don't need a new one. You live in Ohio. There are probably five within driving distance of you. Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546665 Share on other sites More sharing options...
April 5, 20186 yr comment_546668 I paid $40 a year ago. Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546668 Share on other sites More sharing options...
April 5, 20186 yr Author comment_546669 44 minutes ago, siteunseen said: But all you need to do to your flywheel is get it cut or resurfaced like a brake rotor. I've bought many clutch kits over the years but none had a flywheel, I used the existing one. Siteunseen I will do your advise. I will only order the clutch kit and i will resurface the flywheel Thank you gays thank you Zed Head Link to comment https://www.classiczcars.com/forums/topic/59817-1980-280zx-flywheel-and-clutch-kit-advice/#findComment-546669 Share on other sites More sharing options...
