Mystery hardline
Villeman
That T in the first picture looks like my '77 280's vacuum advance that goes to the canisters yellow dot, the advance module and the nipple at the front of the throttle blade.  The second picture looks like a line on my 240's vacuum block under the coil.  I can get pictures later today when I'm home from work.
I'm wondering what model, like Steve says above.
yeah, I can in a little while.
And now I know where that hardline is from.  That's the coolant line that goes around the front of the head to the water pump.  I had one that was attached to the heating plate.  It started at the thermostat housing, then heating plate, then around the head to the bottom radiator hose connector.  That's it in your circle.
It looks like the one that goes around the front of the cylinder head.  I deleted all that stuff in 2011, sorry for my mistake.
Do you think it's vacuum or coolant?  Being metal I'd think coolant but the rubber hose doesn't have a clamp so it could be vacuum???
Edited by siteunseen
  • Who's Online   2 Members, 1 Anonymous, 522 Guests (See full list)
