Posted April 12, 20187 yr comment_547189 Beginning the installation of a different head (E31) on my 72 stock engine. Are new head bolts a good idea? Non turbo or Turbo? Where would you buy them? Are new studs better than new bolts? Where to acquire the timing chain wedge? Other recommendations are a[appreciated Don. Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/ Share on other sites More sharing options...
April 12, 20187 yr comment_547190 New timing bolts are peace of mind. Turbo bolts are stronger though not needed for stock applications. Arp studs are strongest and overkill for stock application. You can make timing wedge from a non-splintery piece of wood. I saw a nice plastic table saw push stick at HF that could be shaped to do the trick: https://www.harborfreight.com/push-stick-33279.html Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547190 Share on other sites More sharing options...
April 12, 20187 yr Author comment_547193 #240260280 Thanks for your quick response. Any suggestions on a good source for the head gasket? Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547193 Share on other sites More sharing options...
April 12, 20187 yr comment_547197 I think the new head bolts are turbo bolts. It's a good idea to put new bolts in but I have re-used them. I don't think that the ARP studs cost too much more than the stock bolts. I use the ARP studs on the race engines and it's nice to not have to buy new bolts or worry if the used ones will hold up. I use a piece of wood to hold the timing chain. It's been working for almost 30 years! Chuck Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547197 Share on other sites More sharing options...
April 12, 20187 yr comment_547198 Most use Felpro head gasket. Spraying with Copper Coat helps it seat better even though it is stamped with instructions to use dry. Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547198 Share on other sites More sharing options...
April 12, 20187 yr comment_547204 I always use the copper coat on the head gaskets. It's recommended by Les Canaday who does a lot of racing with these motors. Also Make sure the threads in the block are clean (compressed air) and the threads on the bolts are clean (when re-using the bolts). I usually wire wheel the bolt threads and then use a lubricant for the install to help reduce galling. Edited April 12, 20187 yr by motorman7 Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547204 Share on other sites More sharing options...
April 12, 20187 yr comment_547208 Also, if it is a new head with fresh valve train parts,be sure to do the 20min non-stop ~2000rpm break-in with it well lubed with correct break-in oil and rebuild grease on the cam. Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547208 Share on other sites More sharing options...
April 12, 20187 yr Author comment_547214 Great information everyone. I think i will go with the ARP Studs, and find some Copper Coat. Found a chain tension wedge online for $10. Head was worked on by madkaw . Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547214 Share on other sites More sharing options...
April 12, 20187 yr comment_547215 I would say it more of piece of mind for new head bolts, I’ve reused bolts several times with no issues. Rebello doesn’t even use studs on his engines , he says Nissan head bolts are just fine. I would not recommend using studs . Just make sure you get everything clean on the block surface . No break in is necessary with that head Edited April 12, 20187 yr by madkaw Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547215 Share on other sites More sharing options...
April 12, 20187 yr comment_547217 Don, i would gladly assist you in anyway with the install. If you have a question you can message me and we can call and talk or whatever. I would be glad to help you hear that run:) Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547217 Share on other sites More sharing options...
April 13, 20187 yr Author comment_547242 Great information. I am hoping to find time soon. These motors are so strong that I have never had to pull on off either of the two I’ve own over the last 22 years. Thanks for the help. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-547242 Share on other sites More sharing options...
April 27, 20186 yr Author comment_548115 Any recommendations for where to purchase new Turbo Cylinder head bolts and Gasket set. Link to comment https://www.classiczcars.com/forums/topic/59852-new-head-install-question/#findComment-548115 Share on other sites More sharing options...
