Posted April 14, 20186 yr comment_547325 Just bought a HS130. Wondering what kind of information you guys can tell me about the following tags. Thanks in advance!! Edited April 14, 20186 yr by JessHS130 Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/ Share on other sites More sharing options...
April 14, 20186 yr comment_547326 http://xenonzcar.com/s130/vin.html What kind of information are you trying to find? Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547326 Share on other sites More sharing options...
April 14, 20186 yr comment_547328 I'm not sure what build date would constitute an early production '79 ZX, or if its even all that important to most people. But as far as ZX's go, I personally prefer '79 through '80. After that you have O2 sensors and automatic climate control and T-tops. All fairly troublesome. The later cars got flat tops with the F54 blocks. You have dish top pistons(assuming its original), with N42 block/N47 head. I have an '80ZX with its original engine that seems to be holding up quite well. These are solid machines.I'm currently building an F54/P90 to put in it either when I feel like it, or this one wears out. The current engine will probably outlast my eagerness to swap it out with the new one. Sent from my [device_name] using http://Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547328 Share on other sites More sharing options...
April 14, 20186 yr Author comment_547329 Wondering if it is a Fairlady. It's a Datsun 280ZX with the tags that's I attached. Original engine and transmission. New to all of this and I got her for a good deal. She runs and drives. Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547329 Share on other sites More sharing options...
April 14, 20186 yr Author comment_547330 Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547330 Share on other sites More sharing options...
April 14, 20186 yr comment_547331 A Fairlady would be right hand drive for the Japanese domestic market. Sent from my [device_name] using http://Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547331 Share on other sites More sharing options...
April 16, 20186 yr Author comment_547430 I just got off the phone with Nissan. The 280ZX began production in 08/1978 so she is "first gen, first run". I will hear back from them within three business days as to which production number this car is. My husband and I own an automotive shop so we will begin to restore her back to her original glory. Â Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547430 Share on other sites More sharing options...
April 16, 20186 yr Author comment_547431 Figured I should probably add a photo of her. Runs and drives all original, engine, transmission, etc... Her paint makes her look rougher than she actually is. Someone before us installed house carpet so that will be the first we pull out of it. Link to comment https://www.classiczcars.com/forums/topic/59864-hs-130-questions/#findComment-547431 Share on other sites More sharing options...
