April 15, 20187 yr Author comment_547383 @Terrapin Z Great! They look fine. I can clean them up with acid no problem. I'll take them as well as the proportioning valve, pressure-loss switch, the brass valve/splitter in the back (above the differential... see picture below) and all tube clips in the engine compartment too. PM me and we can sort out payment and shipping. BIG THANKS! That BRE will be grateful too! He may need more parts too. Glad you have a parts car!  Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547383 Share on other sites More sharing options...
April 15, 20187 yr Author comment_547388 1 hour ago, rcb280z said: That's my question: How did he get the car that high to begin with?  I'm not sure but I will guess alternate centre jacking on the front cross member and then centre jacking on the rear differential can bring it up in steps. The jack will also have to be blocked as the heights increase. I did something similar years ago. Not sure if I have photos but it is an easy way to walk the Z higher. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547388 Share on other sites More sharing options...
April 15, 20187 yr comment_547390 2 hours ago, JSM said: Curious to what he lifts the jack up with. I’m assuming he has to elevate it too?  2 hours ago, rcb280z said: That's my question: How did he get the car that high to begin with? Houdini's levitating lady trick. Pass a hula hoop around It. Maybe he won't saw it half. Edited April 15, 20187 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547390 Share on other sites More sharing options...
April 15, 20187 yr comment_547391 1 hour ago, 240260280 said: Â PM me and we can sort out payment and shipping. BIG THANKS! That BRE will be grateful too! He may need more parts too. Glad you have a parts car! PM sent Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547391 Share on other sites More sharing options...
April 16, 20187 yr Author comment_547397 Thanks again Terrapin Z! Â I'll post some photos after they are restored and installed. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547397 Share on other sites More sharing options...
April 16, 20187 yr comment_547398 5 hours ago, 240260280 said: I'm not sure but I will guess alternate centre jacking on the front cross member and then centre jacking on the rear differential can bring it up in steps. The jack will also have to be blocked as the heights increase. Agreed. I would also assume that's how he raises it. You walk it up one or two layers at a time. If you're going to be doing this often, you might even go through the trouble of screwing or nailing the wood stubs into a square "layer" beforehand and having a stack of them in the corner of the garage. Lift one end up high enough to get a layer under the jack stands and then let it down onto the stands. Then move to the other end of the car and do the same thing. Keep alternating ends until you have "walked" it up one layer at a time to the desired height. As long as the wood is flat-ish and isn't really warped, you will always have three points of contact and it should be stable even while on two stacks and a jack. I sometimes move machinery (surprised?) and utilize the same technique. I just never thought of stacking (and probably pre-building) layers in that geometry. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547398 Share on other sites More sharing options...
April 16, 20187 yr comment_547411 I used this technique before, just when I get to my final height I put in bigger solid blocks for stability. A large beam I cut some pieces from. I am not sure I would want to be under there with it just being on the 2X4's. I suppose that is a personal choice.  Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547411 Share on other sites More sharing options...
April 16, 20187 yr comment_547421 2 hours ago, Terrapin Z said: I used this technique before, just when I get to my final height I put in bigger solid blocks for stability. A large beam I cut some pieces from. I am not sure I would want to be under there with it just being on the 2X4's. I suppose that is a personal choice.   Wood cribbing is still the go to method for supporting large items. Working under a ship on dry dock that is supported by wood cribbing will make one a believer. Yeah, they still support them that way. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547421 Share on other sites More sharing options...
April 16, 20187 yr comment_547425 Couldn't think of the word, "cribbing". Thanks Mark! Holds houses up before and after relocating them. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547425 Share on other sites More sharing options...
April 16, 20187 yr comment_547426 There's also a weight difference between the tribute car and say mine for example but...........totally like what you reminded me of Mark. That cribbing has been around for a long time and will continue to be. I'm going to make me some to make pulling the trany and oil pan easier. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547426 Share on other sites More sharing options...
April 16, 20187 yr comment_547428 12 minutes ago, rcb280z said: There's also a weight difference between the tribute car and say mine for example but...........totally like what you reminded me of Mark. That cribbing has been around for a long time and will continue to be. I'm going to make me some to make pulling the trany and oil pan easier. I'm with you Bob, most likely the tribute is a considerably lighter load. If I was you I think I would go with 2x8s or at least 2x6s.  Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547428 Share on other sites More sharing options...
April 16, 20187 yr comment_547429 Within reason*, I don't think the weight load really matters. As implemented above, the wood is all strictly in compression. So as long as the planks are larger than the jack stand feet (with margin above that for side-to side stability), the dimensions of the wood are pretty much immaterial. As long as you can draw a line straight down from the jack stand feet to the concrete and never pass through any air, those stacks should all be in compression. And for reference, I believe what's used in those pics is 2x6's (1.5 x 5.5). All that said, be safe and don't try this with a stack of 10,000 popsicle sticks.  *Assuming you aren't putting enough compression load on it to explode the wood out the sides. Like tons and tons. Link to comment https://www.classiczcars.com/forums/topic/59865-need-rubber-fuelbrake-line-insulators-and-rear-proportioning-valve-for-73-bre-tribute/?&page=2#findComment-547429 Share on other sites More sharing options...
