Posted May 5, 200321 yr comment_36133 Does anyone know where I can order wiper blade refills that fit the OEM blade/arms? Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/ Share on other sites More sharing options...
May 5, 200321 yr comment_36138 Originally posted by BadDog Does anyone know where I can order wiper blade refills that fit the OEM blade/arms? Motorsport Auto Page 93 of current catalog, Item #12-4450, Price as shown $10.99Probably also available at Courtesy Nissan in Richardson, Texas Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-36138 Share on other sites More sharing options...
July 17, 201410 yr comment_451763 Motorsport Auto Page 93 of current catalog, Item #12-4450, Price as shown $10.99Probably also available at Courtesy Nissan in Richardson, TexasNow many years later and OEM refills are NLA from Courtesy or Motoersport. Is there some other supplier of wiper refills that work with the OEM wiper assembly (1977-78) e.g. Trico, Precision, Bosch? If so, what is the right model??? I think the length is 450mm or 18 inches. Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451763 Share on other sites More sharing options...
July 17, 201410 yr comment_451765 ebay 240z wiper | eBay Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451765 Share on other sites More sharing options...
July 17, 201410 yr comment_451766 Banzai Motorworks Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451766 Share on other sites More sharing options...
July 17, 201410 yr comment_451769 Why did they ever stop making refills? I hate that is so hard to find them now. Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451769 Share on other sites More sharing options...
July 17, 201410 yr comment_451770 Banzai MotorworksDitto that...... Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451770 Share on other sites More sharing options...
July 17, 201410 yr comment_451772 Buy generic replacement blade assemblies at your local auto store, strip out the rubber and insert it into your metal blade frame. Toss the unused frame into your recycle bin or bag. Easy peasy! Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451772 Share on other sites More sharing options...
July 18, 201410 yr comment_451792 Buy generic replacement blade assemblies at your local auto store, strip out the rubber and insert it into your metal blade frame. Toss the unused frame into your recycle bin or bag. Easy peasy!Great idea. It looks like the OEM takes an 18 inch/450mm long wiper refill with an 8mm base. Can anyone confirm those dimensions? (for 77 280z). Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-451792 Share on other sites More sharing options...
July 26, 201410 yr comment_452316 Buy generic replacement blade assemblies at your local auto store, strip out the rubber and insert it into your metal blade frame. Toss the unused frame into your recycle bin or bag. Easy peasy!Good idea. One question though. The Nissan rubber has rubber stops at both ends that prevent the rubber from sliding out. How would rubber from the generic replacement assembly be held in so that it won't slip out? I don't want any chance of scratching my new NOS windshield.Thanks Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-452316 Share on other sites More sharing options...
July 27, 201410 yr comment_452336 Most or all current blades use a small metal spring clip to keep the rubber blade in the frame. That clip will keep the blade firmly locked in your OE frame - been there, done that. I also have OE arms and frames. Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-452336 Share on other sites More sharing options...
July 27, 201410 yr comment_452344 Thanks jfa.So either get generic blade and strip out or buy a generic refill. I see that Trico and Anco offer many types of 18 inch refills with the small metal spring clip. For Trico and Anco, does anyone know which version of the the refills they offer work best with our OEM frames ie. fit on the frame and giving a good wipe on our curved windshields???I guess that I could just buy them and try until I find the best one (not too expensive to experiment) but if someone already has the answer then I would appreciate their insight! Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/#findComment-452344 Share on other sites More sharing options...
