July 27, 201410 yr comment_452347 The last time I replaced mine, I used Anco. I don't know whether they fit better than Trico, but I don't recall any problems with the fit. As I recall, they supply a gazillion little plastic pieced for adapting to whatever you have. Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/?&page=2#findComment-452347 Share on other sites More sharing options...
September 7, 201410 yr comment_454877 FWIW I just put new wiper refills on original arms (I don't know why, it never rains here) and found NAPA 18" refills. They are NAPA 60-1898 $5.59 for 2 blades in the pack. I had to close the tangs a little where the new blades slide thru the original arm retainers for them to fit securely. Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/?&page=2#findComment-454877 Share on other sites More sharing options...
June 10, 20177 yr comment_522781 I don't have a Napa close by. Probably will buy from Amazon as other part stores won't stock blade inserts, they want to sell the whole blade. Are the correct part numbers Anco U-18R or Trico 44-180? I tried to harvest the blades from a Trico "Exact Fit" 18-1, but those are 6mm blades. (Think this is a reference thread as it comes up high on google searches) Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/?&page=2#findComment-522781 Share on other sites More sharing options...
June 10, 20177 yr comment_522784 I buy Trico 44-180 refills from O'Reilly's. Two blades per pack, $7.99 IIRC. Link to comment https://www.classiczcars.com/forums/topic/5988-wiper-refills/?&page=2#findComment-522784 Share on other sites More sharing options...
