Posted April 18, 20186 yr comment_547605 SO I have 1 horn working now (adjustment screw) but the second horn would not work. I took it apart and it has a set of points in it. So I adjusted the screw all the way in but cannot get the points to separate. Are the points supposed to have some separation? Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/ Share on other sites More sharing options...
April 18, 20186 yr comment_547608 I haven't been inside one of those, but I bet there should be no gap and those contacts should be closed. I'm assuming those contacts will open and close rapidly when power is applied to the horn and the oscillation of those contacts is what makes it BEEP. Or at least that's how it's supposed to work. The pressure on the contacts is what is controlled by the pitch adjustment screw and determines how hard those contacts are pressed together. That pressure will change the frequency at which they open and close, and that changes the pitch of the horn. If you have an Ohmmeter... What resistance do you get across the horn? And how about the other one (that works). Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-547608 Share on other sites More sharing options...
April 18, 20186 yr comment_547609 And just because those contacts LOOK closed, are you sure you're getting electrical contact across them? Maybe drag a piece or paper between them to clean up the contacts a little? Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-547609 Share on other sites More sharing options...
April 18, 20186 yr Author comment_547613 Good idea Capt. I will do the contact cleanup and test outside of car Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-547613 Share on other sites More sharing options...
April 18, 20186 yr comment_547618 Good luck, and I hope its that simple. I'm thinking there should be a pretty low resistance measured across the two horn wires coming out of the assy. I bet the working horn is a pretty low, and the non-working one is open circuit for some reason. Could be those contacts, or it could be elsewhere. Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-547618 Share on other sites More sharing options...
May 5, 20186 yr comment_548744 The contacts should be closed. Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-548744 Share on other sites More sharing options...
May 5, 20186 yr Author comment_548749 That is awesome. Thank you. GI Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-548749 Share on other sites More sharing options...
May 5, 20186 yr comment_548764 On 4/17/2018 at 9:21 PM, GIchiro said: Are the points supposed to have some separation? When you start playing with the adjustment screw, I think you're going to find that the adjustment window for optimum sound/volume is pretty narrow. I suggest that you loosen the screw to 75% of its full travel to start. Then, with power applied to the horn, start tightening the screw. Take the horn past its point of max. volume, then back the screw out to re-find that point. Link to comment https://www.classiczcars.com/forums/topic/59891-240z-horn-points-adjustment/#findComment-548764 Share on other sites More sharing options...
