Hey guys, the 240 I got comes with a brand new set of Cosmo adjustable coilovers, racing g spec. Front 6 rear 8 kg rate. Question I have is what will I need to track down to run these. Do I want to run these springs, it won't be a track car but I will drive it with purpose haha. Never done little car suspension. Im used to lifted trucks. Thanks for any direction
Also with a coil over strut setup I'm looking at, does this go so low as new spindles and caliper mounts it or is it just a thread sleeve deal.
Sent from my SM-N950W using Tapatalk
https://www.classiczcars.com/forums/topic/59940-cosmo-coil-over-springs/
Delete it! Just found my answer, reviews on these cosmos are low and sound as though they are too stiff, the struts that buddy bought are kyb so the cheapest of the options. Probably worthless to sell it off at this point so should the time come that I need the chassis to be a roller ill probably install it just for experience.
I'll google around in a quality street machine coil over setup for my 71.
  • 2 months later...
