June 3, 20186 yr Author comment_550336 Since replacing the connectors, my engine has died. It makes no sense to me or the ECU died. or even the coil. The spark plugs looked a bit burned, as if it was oily with misfires. I have an old factory coil on the shelf. Edited June 3, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550336 Share on other sites More sharing options...
June 3, 20186 yr comment_550351 I'm sure replacing those connectors didn't kill your ECU. Probably something simple like you mixed up the thermotime connector and the WTS connector somehow. If you do that, it'll run pig rich, burn you eyes, and foul your plugs in short order. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550351 Share on other sites More sharing options...
June 3, 20186 yr comment_550352 Oh, and forgot... Since the last time this topic was active: I filed the offset tab off the AIRTEX / WELLS5S1523 (SU4115) sensor and installed it. It works great. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550352 Share on other sites More sharing options...
June 4, 20186 yr Author comment_550410 The plugs look fine, as I recently checked, cleaned and gapped them for the summer. The mix should be right. Plus I switched them just in case, with no improvement. The only thing I didn't do is to check the sensors directly, because they are fairly new. The only symptom I couldn't explain is a bit of a misfire, and the spark timing is at 30 degrees even before vacuum advance. something must've jumped? I think I have located a local shop that knows about L-Jet. Edited June 4, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550410 Share on other sites More sharing options...
June 4, 20186 yr Author comment_550430 I'll have to trace those wires. Did I mention the timing is 50 before without the vacuum? Edited June 4, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550430 Share on other sites More sharing options...
June 5, 20186 yr comment_550437 There's nothing that will jump, but it could be that your damper slipped. That would move the timing mark. Easy to check with the valve cover off. Vacuum to the distributor will increase timing advance, not decrease it. Not sure what's going on there. The quickest way to check the complete temperature sensor circuit is to measure resistance at the ECU connector. Pin 13 to ground. Then compare the value to the chart. The best drawings are in the EFI Guide, 1980 version. Shows the connector itself with numbered positions. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550437 Share on other sites More sharing options...
June 5, 20186 yr Author comment_550476 I followed he 280Z EFI book to probe the ECU pins. Everything was correct, even the resistance to the WTS. The only thing I can't check with a VOM is the ignition coil pulses, but the FSM probably tells you how to do that. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550476 Share on other sites More sharing options...
June 5, 20186 yr comment_550482 What does your tachometer do when you try to start it? The weird timing numbers and wet plugs suggest an ignition module problem. Too many ignition pulses (sparks). The 280Z ignition modules seem to die at a fairly constant rate. They're old. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550482 Share on other sites More sharing options...
June 5, 20186 yr Author comment_550486 Right now, the rev counter is (dead) since there is no spark from the HT wire. The last time the engine 'ran' the revs were really jumpy- steady 800 a second, then blip to 14, then quit. I agree it might be an ignition module problem. This might be a chance to switch to the GM HEI module. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550486 Share on other sites More sharing options...
June 5, 20186 yr comment_550487 It's pretty easy. You can do it temporarily in the engine bay as a test, before putting the time in to make it permanent. Or just get ahead of the eventual failure and make it permanent from the beginning. The performance is as good as the stock Nissan modules. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550487 Share on other sites More sharing options...
June 7, 20186 yr Author comment_550577 I did install a generic GM HEI ignition module, and it works fine; the engine runs smoothly without backfires, but the rev counter is not responding, so I'll look into why that is so. If this new ignition module works out, I'll consider the performance Pertronix one, and put the generic one in my spares kit. Would you say all the trouble is worth the $400 for a replacement OE ignition box? Edited June 7, 20186 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550577 Share on other sites More sharing options...
June 7, 20186 yr comment_550593 Weird that our last two posts from yesterday have disappeared. About the condenser. I added a condenser to the negative circuit of the coil when my tach wouldn't function. It worked but I can't say exactly why. Many people have used the HEI module with no tach problems. This is essentially what I wrote yesterday. I saw it post. Good luck. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=2#findComment-550593 Share on other sites More sharing options...
