Hi everyone:
I thought my speedometer was broken so I removed it from the dash in anticipation of having it sent out for repair. I spun the drive shaft on the back of the gauge and it worked perfectly. So I thought maybe the speedometer cable was broken and I tested by spinning it and it and saw the other end spin just fine.
I then realized that the square shaped head that goes into the slot on the back of the gauge was actually not long enough slot into the back of the gauge. I tried pulling on it with needle nose pliers but I can't get the cable to extend out any further. It's a steel cable so I don't think it shrunk any. I can't think of any other any other way to remedy this than to bite he bullet and order a new cable?
Howard
1974 260z
Edited by 882993md
