Posted May 2, 20186 yr comment_548527 Hi All, First post here! I did in fact look through many prior posts about my problem! I went for my first state inspection today and realized none of the blinkers were working. The hazards light up at all four corners normally. When I got home I changed one of the fuses (although it looked fine) and since then the front directionals are working but still not rears. The rear hazard lights are working as are the brake lights. Is this likely a problem with the flashier unit that is located under the steering column covers? THANKS! BTW, I always wanted a Z-car when I was young and now I have a beautiful one! Link to comment https://www.classiczcars.com/forums/topic/59963-72-240z-rear-blinkers-not-working/ Share on other sites More sharing options...
May 2, 20186 yr comment_548530 It's most likely the turn signal switch. https://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/ Link to comment https://www.classiczcars.com/forums/topic/59963-72-240z-rear-blinkers-not-working/#findComment-548530 Share on other sites More sharing options...
May 2, 20186 yr Author comment_548533 Thanks Steve. I should note that the rear blinkers work normally if I have the brake pedal depressed. So which fault would cause this and what should I replace???? Link to comment https://www.classiczcars.com/forums/topic/59963-72-240z-rear-blinkers-not-working/#findComment-548533 Share on other sites More sharing options...
May 2, 20186 yr comment_548537 There could be a cross connection issue, or it could still be the turn signal switch. This isn't something that is plug and play to fix. The good news is that if you have a friend who is good with using a multimeter and reading wiring diagrams, he could take that link I sent you and diagnose the issue. Link to comment https://www.classiczcars.com/forums/topic/59963-72-240z-rear-blinkers-not-working/#findComment-548537 Share on other sites More sharing options...
May 2, 20186 yr Author comment_548543 I'll pull out the switch and have a look! Link to comment https://www.classiczcars.com/forums/topic/59963-72-240z-rear-blinkers-not-working/#findComment-548543 Share on other sites More sharing options...
