Recently Browsing 0
Hello fellow Z'ers,
Recently started having an issue on my Z running really rich and I can see fuel dripping from the nozzle into the barrels.
Car ran excellent for months; then suddenly went to start it and noticed my AFR in the 9's and noticed the drip.
The motor is not stock; has a .495 lift and 290 duration, so keep that in mind.
Idle Jets it ran - 65, but I also tried swapping in 62.5 and 60's and the AFR stayed the same.
Mixture screws are 1.5 turns out.
Fuel Pressure is right below 4psi (with 3.5 - 5psi spec) and was tested with two different gauges
Floats at 30mm (within 29-31mm spec)
Pump nozzle sizes tried: 40 and 50
It drips down from multiple barrels, not just one. Can't seem to figure out why this is happening since nothing was changed since it last drove fine.
Any ideas where to start next? Thanks!
https://www.classiczcars.com/forums/topic/59985-oer-dripping-fuel-inside-barrels/Share on other sites
