May 9, 20186 yr Author comment_548981 Siteunseen. By just looking at the images you post. It look similar to mine except the green and wire wires. Could the P.O. possibly switch the location. See picture and thank you for replyingĀ Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-548981 Share on other sites More sharing options...
May 9, 20186 yr comment_548982 You are definitely missing a wire. My $0.02: The wire for the running lights came off of the contact on the switch. The PO starting hacking wires because he didn't know how to fix it properly. Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-548982 Share on other sites More sharing options...
May 9, 20186 yr Author comment_548988 Hi steveJ. Could it be the green and white wire from my original post? Currently no running lights/taillights thanks for your replyĀ Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-548988 Share on other sites More sharing options...
May 9, 20186 yr comment_548989 You nailed it. See, it's not that hard to figure things out. Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-548989 Share on other sites More sharing options...
May 9, 20186 yr Author comment_548991 Steve do you suggest to switch those green wires and replicate what siteunseen posing Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-548991 Share on other sites More sharing options...
May 9, 20186 yr comment_548995 Shoot me a reminder on Friday so I can give you a more detailed breakdown on what you should do. Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-548995 Share on other sites More sharing options...
May 9, 20186 yr Author comment_549001 Ok ? thanksĀ Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-549001 Share on other sites More sharing options...
May 9, 20186 yr comment_549003 It's clear from the scratch marks on the little metal tabs of that switch that someone has opened that thing up in the past. I'm sure it's all related. Maybe the wire's solder joint was weakened by that process, Maybe they took it off completely during that process and didn't do a good job of putting it back on. Maybe the headlight side rocker inside the switch was burned beyond recognition so they swapped the one from the running lights over. There might not even be a rocker on the running light side if that's the case. Maybe they took that wire off intentionally to use a separate mounted switch somewhere else. Just thinking out loud as to why that switch and wiringĀ is the way it is now. I think you have identified the "what". I'm just musing about the "why".Ā Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-549003 Share on other sites More sharing options...
May 10, 20186 yr Author comment_549036 Hey Captain thanks for your post. I was the one that opened the circuit because head lights were not working so I cleaned the carbon built up. Now headlights are working. I was just trying to figure out the green and white wire. See my previous post. Thanks for any advise Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-549036 Share on other sites More sharing options...
May 10, 20186 yr comment_549037 Do you know how to use a multimeter? It would be good to know if you have continuity between that green/blue wire and the contact that is missing a wire. Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-549037 Share on other sites More sharing options...
May 10, 20186 yr comment_549038 18 minutes ago, krZing said: I was the one that opened the circuit because head lights were not working so I cleaned the carbon built up. Gotcha. Working back through PO's work is always tough.Ā Hope the rest of it goes smooth! Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-549038 Share on other sites More sharing options...
May 10, 20186 yr comment_549086 21 hours ago, krZing said: Hey Captain thanks for your post. I was the one that opened the circuit because head lights were not working so I cleaned the carbon built up. Now headlights are working. I was just trying to figure out the green and white wire. See my previous post. Thanks for any advise Here is a photo a wire diagram I have used for sometime now. Here is a section that shows the Hazard and ignition switch area and shows a Green/white wire. Maybe it will help. Could that connector go to the Flasher? Edited May 10, 20186 yr by 7tooZ Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=2#findComment-549086 Share on other sites More sharing options...
