Regarding replacing the hood:  Early cars are known to have slightly different hoods.  You should try to save it if you can if you ever plan on selling the car.  Crazy Z people know about the different hood and will want it to be on the car vs. the later one.
Yes, the 69 hood is different in several areas. I compared it to my later Series 1( #8701) and Series 2 (#23381). The most striking different is that reinforced piece at the upper corners. The 69 hood doesn't have them. So yes, we're trying to save the hood of #187. As you can see, the front lip of the hood was originally bent down and in, and shows a lot of fillers once the paint was stripped. cbc769144a301eed8394224baf9a83af.jpg98a127fe0fd0d61cc13279c981749062.jpg7f36e405a508b5275440b2231bb3d20a.jpg0814430c83c4ff8fdd607bc56190a227.jpg
Sent from my SM-G975U using Tapatalk
  • 2 years later...
A few other unique oddities of the 69's.  The discs have these cutouts and the dust covers are different than the later models.
Edited by drpchuynh
Brake lines were too rusty. Most fell apart upon disassembly. Rod had to source from a donor car. Luckily the brake lines are consistent throughout the early years.
Apologized for the sequencing. I should have posted these before the others. Rod lined it with the vapor barrier, rubber barrier for acoustic shielding, and threw the old jute back on.
