Posted May 14, 20186 yr comment_549249 Hello Guys, 72 240Z. I'm almost ready to drive the car I bought last year, but I can't get a brake pedal when engine running. It feels pretty firm with engine off. I have replaced everything except booster and lines. I have bleed multiple times, so I'm sure of no air in system. In my experience when a booster is bad the pedal will be harder when car started. Any idea? Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/ Share on other sites More sharing options...
May 14, 20186 yr comment_549251 On 5/14/2018 at 1:52 AM, Rio24 said: Edited May 14, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549251 Share on other sites More sharing options...
May 14, 20186 yr Author comment_549252 That's exactly what is means. Doesn't really drop to the floor on its own. Just no resistance when pressing down. Pedal does return to the top. I bought the car with a seized engine and got that going . Next was the brake system need attention. I replaced calipers pads rotors and drums ,wheel cylinders ,shoes and hardware. Not sure what else you need. Thanks for your time zed head Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549252 Share on other sites More sharing options...
May 14, 20186 yr Author comment_549253 The car has been sitting for 10+ years. Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549253 Share on other sites More sharing options...
May 14, 20186 yr comment_549255 My mistake. Edited May 14, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549255 Share on other sites More sharing options...
May 14, 20186 yr Author comment_549256 OK Zed head. Just giving you details. Master has been replaced Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549256 Share on other sites More sharing options...
May 14, 20186 yr comment_549258 Good luck. Edited May 14, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549258 Share on other sites More sharing options...
May 14, 20186 yr Author comment_549259 I don't understand your point? I'm here for help Zed. You wanted details, I gave them to you. What about the bleed screws? They are all working properly. I bled the system a few times. Pressure, vacuum and manually bled just today. Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549259 Share on other sites More sharing options...
May 14, 20186 yr Author comment_549260 I'm sorry but I thought the title of my post explains my symptom Zed head. Everything has been replaced except lines and booster. Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549260 Share on other sites More sharing options...
May 14, 20186 yr comment_549261 Back to the future... Edited May 14, 20186 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549261 Share on other sites More sharing options...
May 14, 20186 yr Author comment_549262 Is that what you call helping? More like wasting time. Glad I could help with your boredom sir. Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549262 Share on other sites More sharing options...
May 14, 20186 yr comment_549264 Although, the part about boredom is on-point. So, thank you for that. Link to comment https://www.classiczcars.com/forums/topic/60027-no-brake-pedal-when-car-running/#findComment-549264 Share on other sites More sharing options...
