Misfiring while cruising
On 9/27/2018 at 8:10 PM, jalexquijano said:
Stop complaining! You are not helping. Just bashing
I feel bad about saying that, I'm truly sorry.  I had a Porsche and remember post from a guy in Panama that went by a very similar username as you use on here.  Had a '60 VW Beetle.  That was 10 years ago at least.  Are you Jorge Alex or Jalex?
Again I'm sorry if I've confused you with another person.
Edited by siteunseen
Sorry but your are confused. I am very grateful with all the help you guys have given me. Mark has guided me a lot.
On 9/29/2018 at 8:43 AM, Mark Maras said:
 Ok, If you've completed all the tests and found everything looking good put it back together with good (or new) plugs and take it for a run and then let it idle. I'm hoping that you've improved the connections while doing the tests. Let us know.
Im taking it for a test drive today and will leave it idling for 20 mins to simulate a traffic jam. Should i leav the timing at 14 btdc?
Did a 7 min run some 10 to 20 seconds stops. These were the results. Still have not left it idling. 1 2 3 4 5 6 spark plug order
