October 11, 20186 yr comment_559390 On 10/11/2018 at 11:10 AM, AK260 said: I think your speedo may be a little optimistic - the longest R180 was a 3.364 which means you should get 22 (ish) mph per 1000rpm. Unless of course your gearbox has a super long top gear. Mine is pessimistic around 30mph (i.e. Shows 25mph) then gets accurate at 80 and optimistic above 90! Ahem - All tested on a track of course, officer! Don't always trust your old dials. Other possibility is that your rev counter is being pessimistic and you really are doing 100 in which case your real (not indicated) revs are around 4.5K RPM! And if you think that the max speed of your car is around 120mph and max torque at c.5.5krpm, then the 22mph / 1000 rpm works. Or are you running some super tall tyres!? ? I have never either the tachometer or the speedometer from the dash to restore them. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559390 Share on other sites More sharing options...
October 12, 20186 yr comment_559409 You can do a speedometer accuracy check by driving with a portable GPS navigation unit in the car (Garmin, TomTom, perhaps even your cell phone with mapping app, etc.). The GPS unit will show your actual speed and you can compare it to your speedometer reading. Dennis Edited October 12, 20186 yr by psdenno Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559409 Share on other sites More sharing options...
October 12, 20186 yr comment_559414 Back in the late '90s when I had my boat a friend paid $3,000 for a GPS and we all used it to get the correct speed. The factory set up was only good to about 70 or 80 mph. I put that in a pocket on the back of my seat. Made a few passes and it showed 101. I lost interest soon after that and sold the boat. Why do I spend all my time and money getting something to the top then lose interest? As bad as i hate to say it I'm scared to drive the 240. Still enjoy talking with my friends on here but the car sits all alone. How much does Mrs Dennis charge per hour? Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559414 Share on other sites More sharing options...
October 12, 20186 yr comment_559418 I have an app on my phone "speed cast" I believe that will give GPS speeds and acceleration numbers Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559418 Share on other sites More sharing options...
October 12, 20186 yr comment_559421 Thank you Charles! I'll have to read up on that. Mine runs around 75mph @2,200rpm. 80 @ 2,500. I changed out the speedo cog and have 15" tires. Seems steady compared to traffic on the interstate but that app would let me know for sure. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559421 Share on other sites More sharing options...
October 12, 20186 yr comment_559425 On 10/12/2018 at 12:42 AM, siteunseen said: Why do I spend all my time and money getting something to the top then lose interest? As bad as i hate to say it I'm scared to drive the 240. Still enjoy talking with my friends on here but the car sits all alone. How much does Mrs Dennis charge per hour? I'm sure you would get the "friends and family" rate. This week, she's been an expert witness at the murder trial of someone she worked with several years ago. You would be a nice break for her. Dennis Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559425 Share on other sites More sharing options...
October 12, 20186 yr comment_559428 On 10/12/2018 at 1:55 AM, psdenno said: I'm sure you would get the "friends and family" rate. This week, she's been an expert witness at the murder trial of someone she worked with several years ago. You would be a nice break for her. Dennis We hope... Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559428 Share on other sites More sharing options...
October 12, 20186 yr comment_559433 Would one of these help? https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6 Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559433 Share on other sites More sharing options...
October 12, 20186 yr comment_559440 I've used similar things before but the the cheapest way to see if you are getting spark is to get the engine running, set the fast idle to around 1.1krpm - take a plug lead off at a time and point it to something metal on the block - you will soon see/hear the spark. BTW did you get the new leads? Remember the old ones can have a break inside and give intermittent spark / intensity when vibrating under normal conditions.As a rule of thumb you should be sitting somewhere between 2.8-3.1k rpm at 70mph depending on which variation of diff ratios/gearbox / wheels you have. The typical range is somewhere between 21.5-22.5 mph per 1000rpm.Use a free app on your phone like track addict and you will have a better view of your speedo accuracy. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559440 Share on other sites More sharing options...
October 12, 20186 yr comment_559443 On 10/12/2018 at 1:25 AM, siteunseen said: Thank you Charles! I'll have to read up on that. Mine runs around 75mph @2,200rpm. 80 @ 2,500. I changed out the speedo cog and have 15" tires. Seems steady compared to traffic on the interstate but that app would let me know for sure. what kind of gearing are you running? Im seeing an issue on my Z where the car falls flat on its face in 4th gear, running a 3.36 and close ratio gearbox. It used to occur in 3rd gear @4k rpm, but I was able to tune that issue out, im starting to thing its the gearing thats "bogging" down the car if thats possible. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559443 Share on other sites More sharing options...
October 12, 20186 yr comment_559444 OE R180 with the wide B 5 speed. Mine does well in fourth gear. That's where it stays unless I'm on an interstate. Edited October 12, 20186 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559444 Share on other sites More sharing options...
October 12, 20186 yr comment_559445 On 10/12/2018 at 9:14 AM, siteunseen said: OE R180 with the wide B 5 speed. What are you doing up or have you been up all night? Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=18#findComment-559445 Share on other sites More sharing options...
