October 24, 20186 yr comment_560205 Just receive a new set of NGK spark plug cables. Let me try them. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560205 Share on other sites More sharing options...
October 24, 20186 yr comment_560239 @jalexquijanoThe new set of plugs to go with the new wires is a good idea. Good luck with the test runs. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560239 Share on other sites More sharing options...
October 24, 20186 yr comment_560240 Mark i did tried the timing gun test and it only reads the timing marks when fastened to spark plug cable 1 and 6. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560240 Share on other sites More sharing options...
October 25, 20186 yr comment_560257 4 hours ago, jalexquijano said: Mark i did tried the timing gun test and it only reads the timing marks when fastened to spark plug cable 1 and 6. Did the timing light you used have a tachometer on it? Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560257 Share on other sites More sharing options...
October 25, 20186 yr comment_560261 No Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560261 Share on other sites More sharing options...
October 25, 20186 yr comment_560324 @jalexquijanoAssuming you've installed the new plugs and wires, drive it for a few days, pull all the plugs and tell us they look great or send pics. Correction, send pics either way. Almost forgot. Put the timing light away, at least for now. Edited October 25, 20186 yr by Mark Maras Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560324 Share on other sites More sharing options...
October 25, 20186 yr comment_560325 Will install new wires today Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560325 Share on other sites More sharing options...
October 26, 20186 yr comment_560384 On ‎10‎/‎17‎/‎2018 at 2:19 PM, AK260 said:   Agreed! Plug fouling at idle could be caused by other things like mix, lack of vac advance, etc. Get her firing well first and then sweat the other stuff later. ;) Is it safe to assume you've already changed your cap and rotor?  I changed rotor, cap and now spark plug wires (NGK Blue). Will test the car tomorrow morning. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-560384 Share on other sites More sharing options...
November 5, 20186 yr comment_561010 Result of plugs in order 1 2 3 4 5 6 stepping on the gas at 100 mph after changing brand new ngk blue spark plug wires and bosch rotor and cap. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-561010 Share on other sites More sharing options...
November 5, 20186 yr comment_561018 Â A big improvement. No more fouled #4. I don't have an answer to why #s 2, 5, &6 have a slight rusty color on them. I wouldn't worry about it for now. Does anyone have a guess? I'd drive it for a while and check them again. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-561018 Share on other sites More sharing options...
November 5, 20186 yr comment_561026 Do they still foul at idle? Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-561026 Share on other sites More sharing options...
November 5, 20186 yr comment_561028 Havent tested at idle yet. Link to comment https://www.classiczcars.com/forums/topic/60072-misfiring-while-cruising/?&page=20#findComment-561028 Share on other sites More sharing options...
