SS Bumpers from Vietnam
14 hours ago, 7tooZ said:
My experience with SS bumpers from Harrington is you must be very careful cleaning them. They scratch very easy and are not easy to bring back to the original shine.
72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler.
i've been told steel wool 0000 to be one of the best solution...tested?
22 hours ago, 7tooZ said:
Are you saying you used steel wool on yours and it equaled the original finish?
No! I've been advise to do so by my carbody shop owner. Professionnal tip i cannot give feedback on.
My comments were in regard to my experience with Harrington bumpers I had
purchased. Not all SS is the same. Sounds like others have had a better experience.
  • Thanks 1
Just out of curiosity, what did you find when you used steel wool on your bumpers, scratching?
It dulled the finish. Further polishing was difficult without removing the bumper. Took it to a professional who quoted 250.00 to polish. So I gave up and gave away the bumpers and had two bumpers rechromed at a quality shop. One of the best things I added to my car.
  • Thanks 1
I heard that steel wool is often a bad idea on stainless because it embeds rust-able particles in an otherwise non-rusting surface. Doesn't hurt the overall integrity of the material, but can make it look poorly. Same with wire wheeling.
Note that "I heard it on the internet", so take that for as much truth as it's worth. YMMV.
I have heard the same thing. Although I have no actual experience to confirm it.
