So, I know it was Porsche, but what model? I've got a Boxster in the garage and I've already measured the seats.
Boy... Would SWMBO sure be surprised if she went out one day and found her seats weren't in her car anymore!!   :ph34r:
PS - Sorry, OP for the thread jack. I think we're almost done.
It’s been a bit - can’t remember the model. Was late 90’s I believe.
Please note this was a huge PITA project. Definitely not a “bolt-in”. The seats had a manual piston-assisted height adjustment, which I had to remove/collapse and weld closed to get them low enough to clear the headliner, the mounting point width was too wide so I had to fab new mounts, the tracks were too long so I had to cut/weld them and reconfigure the slide adjustment lever, and the floor pan on the drivers side (propeller shaft hump) required some “adjustment” with a 4 lb hammer to make room. I don’t recommend this unless you are hell-bent on making it happen and willing to modify your z a bit.
13 hours ago, Patcon said:
we're getting close, so no stupidity before Atlanta!
Wait... Nothing stupid?? Nothing? Am I supposed to live in a plastic bubble of good judgment for the next month??
I was supposed to go for a run with scissors today.
Well that narrows it down some. LOL
I put Fiero seats in mine and it wasn't easy. I didn't have to bash the hump on the floor (BTW - it's for the catalytic converter on such equipped models), but I had all the same mounting issues. Not an easy project.
