June 2, 20186 yr Author comment_550298 On 6/2/2018 at 6:13 PM, Patcon said: @grannyknot Thanks Patcon. Maybe my search skills are poor, but I cannot find the post. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550298 Share on other sites More sharing options...
June 2, 20186 yr comment_550302 On 6/2/2018 at 6:25 PM, loudoun said: Thanks Patcon. Maybe my search skills are poor, but I cannot find the post. I have found the embedded search engine is subpar to using google, unfortunately Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550302 Share on other sites More sharing options...
June 2, 20186 yr comment_550307 On 6/2/2018 at 5:44 PM, loudoun said: The rollers are intact, but the backing plastic piece behind them are either broken or non existent. I pulled regulators from some of my parts cars and same deal. Any ideas? What do you mean by "backing plastic piece"? Most of the fixes end up using obscure local hardware store parts, or things from the internet, like tarp grommets. I think that you'll need to use your own ingenuity. But some pictures of what you're working with would help us generate ideas. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550307 Share on other sites More sharing options...
June 2, 20186 yr comment_550313 On 6/2/2018 at 6:01 PM, loudoun said: I think it was grannyknot, but I cannot find it. Well that took some searching, it was actually @240Ziggy that came up with the idea, I just jumped on the bandwagon, here it is, Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550313 Share on other sites More sharing options...
June 5, 20186 yr comment_550432 Search for "tarp grommets" at walmart's web site....6 for less then $3, they will need minor sanding but do work great. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550432 Share on other sites More sharing options...
June 5, 20186 yr comment_550438 Just had a thought about replacing that part - SteelStik epoxy. You can shape it in to the desired form and it will harden in place. It's like putty and won't run. If you don't want to grind the pin out then replace it. Do a test run to get a feel for how fast it sets up. Wear gloves. https://www.jbweld.com/products/steelstik-epoxy-putty-stick Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550438 Share on other sites More sharing options...
June 5, 20186 yr Author comment_550444 On 6/2/2018 at 8:32 PM, Zed Head said: What do you mean by "backing plastic piece"? Most of the fixes end up using obscure local hardware store parts, or things from the internet, like tarp grommets. I think that you'll need to use your own ingenuity. But some pictures of what you're working with would help us generate ideas. Zed Head. Here you go. I agree, pics help. The screwdriver is pointing to it. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550444 Share on other sites More sharing options...
June 5, 20186 yr comment_550445 That's a good one right? Your problem is a broken or missing one? That part is really just a "location" or spacing device. There are probably many ways to make something to do the job. Something like a split collar clamping device. In my case, the roller itself broke apart. So I had to remove the shaft and figure something out. It's the shaft removal and replacement that is difficult. I don't have a welder. Here are some examples of split collars. Metal would probably be "scrapy" in action. Plastic would be best. https://www.amazon.com/s/ref=nb_sb_noss_2?url=node%3D16411921&field-keywords=split https://www.grainger.com/category/shaft-collars/shaft-couplings-collars-and-universal-joints/power-transmission/ecatalog/N-1d90?refineSearchString=split&searchString=Shaft%2BCollars&ts_optout=true#nav=%2Fcategory%2Fshaft-collars%2Fshaft-couplings-collars-and-universal-joints%2Fpower-transmission%2Fecatalog%2FN-1d90Z1yyta09%2FNtt-split%3Fsst%3DAll%26ts_optout%3Dtrue http://shaft-collars-couplings.staffordmfg.com/viewitems/standard-round-bore-shaft-collars/two-piece-split-clamp-type-shaft-collars Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550445 Share on other sites More sharing options...
June 5, 20186 yr comment_550446 You should inspect that roller closely while it's out. Maybe do the whole rebuild on the assembly. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550446 Share on other sites More sharing options...
June 5, 20186 yr Author comment_550447 On 6/5/2018 at 3:20 AM, Zed Head said: That's a good one right? Your problem is a broken or missing one? That part is really just a "location" or spacing device. There are probably many ways to make something to do the job. Something like a split collar clamping device. In my case, the roller itself broke apart. So I had to remove the shaft and figure something out. It's the shaft removal and replacement that is difficult. I don't have a welder. Here are some examples of split collars. Metal would probably be "scrapy" in action. Plastic would be best. https://www.amazon.com/s/ref=nb_sb_noss_2?url=node%3D16411921&field-keywords=split https://www.grainger.com/category/shaft-collars/shaft-couplings-collars-and-universal-joints/power-transmission/ecatalog/N-1d90?refineSearchString=split&searchString=Shaft%2BCollars&ts_optout=true#nav=%2Fcategory%2Fshaft-collars%2Fshaft-couplings-collars-and-universal-joints%2Fpower-transmission%2Fecatalog%2FN-1d90Z1yyta09%2FNtt-split%3Fsst%3DAll%26ts_optout%3Dtrue http://shaft-collars-couplings.staffordmfg.com/viewitems/standard-round-bore-shaft-collars/two-piece-split-clamp-type-shaft-collars That is one from a spare that I had off a parts car. Thanks for the links I will take a look. I did have to put the door back together for a car show. I robbed the window roller off another car, as it was non-existent on the one I was working on. That seems to have done the trick for now. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550447 Share on other sites More sharing options...
June 5, 20186 yr comment_550481 Zed is there a source for parts to complete rebuild the assembly ? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550481 Share on other sites More sharing options...
June 5, 20186 yr comment_550483 I don't think so. I meant to collect all of the tricks we've described in these threads, to replace the backing guide piece that broke on yours and others, and the roller itself, that broke on mine. Link to comment https://www.classiczcars.com/forums/topic/60103-240z-window-woes/?&page=2#findComment-550483 Share on other sites More sharing options...
