June 10, 20186 yr comment_550747 Oh, and I used VW connectors on my injectors as well, but I used a different version with end release clips instead of the one single side release. I found I liked them much better for the injectors, but I liked the side release in the other locations better. I used to have a pic posted, but photobucket extorted it out of existence. I'll get a new pic loaded up when I get a chance. Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-550747 Share on other sites More sharing options...
June 10, 20186 yr comment_550781 On 6/3/2018 at 9:31 AM, 240260280 said: I may have a few kicking around. @240260280Â Philip, after an electrical mishap I think I'm in need of your fuse blocks as well to replace the fusible links on my '78 280Z. Could we arrange that please? Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-550781 Share on other sites More sharing options...
June 10, 20186 yr comment_550787 20 hours ago, grannyknot said: The connector caps for the fuel injectors are working but in rough condition so I was going buy new ones and splice them in but @240260280 suggested going to the wreckers and look for Audi/VW. I got enough to change every connector on the car for $10. Passat's had all the right stuff. That is a very nice set of connectors. Proper spacing and everything. You might consider using a male and female connector (Weatherpack is popular, I think) at the end that you cut so that you can just remove all six as an assembly whenever needed. Much easier than splicing all six separately. Looks like it was made for it. http://www.whiteproducts.com/connectors.shtml Edited June 10, 20186 yr by Zed Head Put my words in the wrong spot. Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-550787 Share on other sites More sharing options...
June 21, 20186 yr Author comment_551431 Good idea ZH but I had them spliced in by the time I read your post. Getting some surface finishing done, console was lightly sanded with 240 grit a 2 coats of SEM Landau black, All of the bumper rubber looks pretty sad, can't tell if a PO painted them at some point or that is just age but sanded all the rubber with 240 grit them burnished with the 3M Grey scuff pads then a couple of coats of Auto Glim tire dressing, This is a spare valve cover that will go on the 280z, wet blasted, a coat of GIBBS oil. Â Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551431 Share on other sites More sharing options...
June 22, 20186 yr comment_551442 Dang man! You could make my current girlfriend look good. She's sweet but has a "butter head". Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551442 Share on other sites More sharing options...
June 22, 20186 yr comment_551449 On 6/7/2018 at 10:27 PM, Captain Obvious said: I ditched the inflat-o-matic spare for an always inflated donut spare a while ago. Details are here, but pics are dead because photobucket sucks:https://www.classiczcars.com/forums/topic/55424-always-inflated-mini-donut-spare-for-7778/ The 77 and later cars are tough because of the reduced tire well diameter. The summary is I'm running a T115/70/14 space saver tire on an old 4 inch wide rim from a Datsun Roadster. That's the largest rubber I could get into the spare tire well on the 77. Let me know if you want me to reload the pics and I can do that when I get the chance. Would you measure the height of the tire from the ground? I’m curious if this would fit the tire well in my 300zx. Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551449 Share on other sites More sharing options...
June 22, 20186 yr comment_551486 I measured the overall height at about 21.5 inches (+/- .25 inch for parallax error). I uploaded a couple pics. Measuring the height: Here it is snug as a bug in the back of my 77: And (as embarrassing as it is...) here's a pic of it on the car when I did a short test run to make sure it actually worked: Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551486 Share on other sites More sharing options...
June 23, 20186 yr comment_551519 Looks like a great car you found. Very good condition, just a little dirty and dusty. Should be an easy resto for you time around. 77 model, its before august 77 anyway. Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551519 Share on other sites More sharing options...
June 23, 20186 yr Author comment_551524 1 hour ago, EuroDat said: Looks like a great car you found. Very good condition, just a little dirty and dusty. Should be an easy resto for you time around. 77 model, its before august 77 anyway. Thanks Chas, no major problems yet, it's a nice change. Before Aug. 77, that's good to know, PO removed the B pillar ID plate for painting and lost it. As far as I know there is no way to replicate it, Banzai Motorworks only produces the door tags up to /73. You know the car was built before Aug. because of some detail you are seeing? Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551524 Share on other sites More sharing options...
June 23, 20186 yr comment_551527 An early 77', Â till June I believe, had a sloped rear deck. Â A late 77' had a flat rear deck like all the other Z's. Â I had a June 77' parts car and it had a flat deck, that's what I'm basing off of. Edited June 23, 20186 yr by gwri8 Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551527 Share on other sites More sharing options...
June 23, 20186 yr comment_551534 Mine is a 5/77 with a flat deck if that helps. I think they were sloped before 5/77, IIRC. Â Edited June 23, 20186 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551534 Share on other sites More sharing options...
June 23, 20186 yr comment_551536 Yep, The rear deck and your fuel pressue regulator valve FPR is early model. Both changed in july 1977. I started a thread on these differences over the years, but there is somethinv wrong with it and it opens all wierd and photo's all ovef the place. I will start a new one and post all I have on that one. Im on my tablet so don't have many photo's, but here are the two fpr's Early (before August) has two inlets and one outlet with 90 degree bend. Late (August 1977 onwards) has one inlet and one outlet with 90 degree bend The dates with these changes are not hard just like the 240Z changes. They seemed to change a lot of little things in the July / August period. Edited June 23, 20186 yr by EuroDat Link to comment https://www.classiczcars.com/forums/topic/60126-just-what-the-doctor-ordered-1977-280z/?&page=4#findComment-551536 Share on other sites More sharing options...
