Just what the Doctor ordered. 1977 280z
grannyknot
On 6/2/2018 at 10:23 PM, Captain Obvious said:
The fantastic 77 color wiring diagram was created by Wayne @wal280z.
Here's the latest. It's Revision "M". It includes the two changes mentioned above (voltage regulator and illumination light in the Temp/Oil gauge):
And if you want to see any of the history of changes, here's a thread with some details:
https://www.classiczcars.com/forums/topic/11727-color-wiring-diagram-for-280z/?page=3
@Captain Obvious   Thank you, I appreciate the kind words and your love for the diagram.
  • Like 4
  • 1 month later...
  • 1 month later...
The 280 is up on the rotisserie now, cleaning up some of the previous guys welding work, only about 1/3rd into the undercoat scraping:cry:
Underneath the crud is a cream coloured coating and bare metal underneath that, can anyone tell me exactly what that is, 2k primer, single primer, paint?  The last pic is a scraper I made out of an old carpet knife, I sharpened the outer edge as well as the inner and it allows you to get into most of the curves and crevices, wish I had thought of this years ago.
MEK would be the better solvent.  The MEK rub test is an actual coatings test, to assess degree of cure of 2K type coatings.
It's a people-power test but they've tried to make a machine for it.  A look in to the world of paint.
http://www.trl.com/paint_solvent/
https://gardco.com/pages/abrasion/mekrubtest.cfm
  • 4 weeks later...
Well, I had no intention on painting this car much less going down to bare metal but... here I am. Someone in the past filled in the antenna hole and drilled another one and then that was filled in as well, so which is the stock hole?  I thought at first it was the front one but I don't remember cutting into the bodyline like that.
  • Who's Online   1 Member, 0 Anonymous, 261 Guests (See full list)
