Posted June 5, 20186 yr comment_550468 So I ordered new shock struts, all 4. They are KYB Gas A Just. Long story short, the rear end sits about 2 inches too high, the ride is very harsh. So I contacted KYB and ask them to research the part number with them telling me I had the correct part. I went back and forth with them saying that something is not right, but there was nothing else they could offer me to help solve the problem. I drover the car around for a few months thinking they may settle, but nothing changed. Has anyone had a similar issue? Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/ Share on other sites More sharing options...
June 5, 20186 yr comment_550469 What are the part numbers and what is the car? The 280ZX does not have struts in the back. It has what's called a trailing arm suspension design. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550469 Share on other sites More sharing options...
June 5, 20186 yr Author comment_550475 2 hours ago, Zed Head said: What are the part numbers and what is the car? The 280ZX does not have struts in the back. It has what's called a trailing arm suspension design. 82' NA. KYB KG9113 Gas-A-Just Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550475 Share on other sites More sharing options...
June 5, 20186 yr comment_550477 Just trying to help. Sorry, didn't really have a good picture of the ZX rear suspension. I guess it is a strut, by strict definition. Rockauto says that's the correct part. I could ask a bunch more questions but I don't have a ZX anyway. Who installed them, did you mess with the springs, did it ride correctly before, do the new ones look like the old ones, etc. The basics would be to check that the shocks aren't bottomed out. The springs hold the car up, the shocks might only add 1/4" from the internal gas pressure. Good luck. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550477 Share on other sites More sharing options...
June 5, 20186 yr Author comment_550478 18 minutes ago, Zed Head said: Just trying to help. Sorry, didn't really have a good picture of the ZX rear suspension. I guess it is a strut, by strict definition. Rockauto says that's the correct part. I could ask a bunch more questions but I don't have a ZX anyway. Who installed them, did you mess with the springs, did it ride correctly before, do the new ones look like the old ones, etc. The basics would be to check that the shocks aren't bottomed out. The springs hold the car up, the shocks might only add 1/4" from the internal gas pressure. Good luck. I did all the work, everything is correct. It doesn't make sense that just changing out the shock makes the car sit higher in the rear. Looks like Starsky and Hutch Torino. So I installed an old set of worn out struts I had, and it sits back normal. Something ain't right. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550478 Share on other sites More sharing options...
June 5, 20186 yr comment_550480 Did you examine the two parts, side-by-side? Check the spring perch, push the rod in to the shock body, all the way down? You can do it by hand or by putting your body weight on it. It's actually good exercise. You have the KYB's right there, right? Give it a stroke. Measure the distance to the spring perch. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550480 Share on other sites More sharing options...
June 6, 20186 yr Author comment_550523 6 hours ago, Zed Head said: Did you examine the two parts, side-by-side? Check the spring perch, push the rod in to the shock body, all the way down? You can do it by hand or by putting your body weight on it. It's actually good exercise. You have the KYB's right there, right? Give it a stroke. Measure the distance to the spring perch. All even, nothing out of place. Nothing to see. Just sits too high, and ride is very harsh. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550523 Share on other sites More sharing options...
June 6, 20186 yr comment_550524 Why are the springs mounted? They should be on the old set of shocks that you reinstalled. It's looking like you just got some higher rate springs on your new KYB's. It's not the shocks it's the springs. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550524 Share on other sites More sharing options...
June 6, 20186 yr Author comment_550525 15 minutes ago, Zed Head said: Why are the springs mounted? They should be on the old set of shocks that you reinstalled. It's looking like you just got some higher rate springs on your new KYB's. It's not the shocks it's the springs. I had an old set lying around, put them on just to see if the car would lower. Dont have the spring compressor handy. You think those are higher rate? It seemed they were the same as the old ones. I'll recheck. Thanks. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550525 Share on other sites More sharing options...
June 6, 20186 yr Author comment_550526 21 minutes ago, Zed Head said: Why are the springs mounted? They should be on the old set of shocks that you reinstalled. It's looking like you just got some higher rate springs on your new KYB's. It's not the shocks it's the springs. Here's the ones I just put on, factory strut, dropped the rear of the car 2+ inches, rides normal. Dimensions are the same as the KYB sitting side by side. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550526 Share on other sites More sharing options...
June 6, 20186 yr comment_550527 If you didn't use the same springs then you can't really say it's the shocks. If you like the ride height of the car is it is now, with the old shocks, then the odds are in your favor if you take those same springs and put them on the KYB's. You might get an extra 1/4 to 1/2" inch. I'm sure that they're the same internal pressure as the KYB's we use on the 280Z's. We get a little pop from the gas struts too. Not 2" though. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550527 Share on other sites More sharing options...
June 6, 20186 yr Author comment_550528 4 minutes ago, Zed Head said: If you didn't use the same springs then you can't really say it's the shocks. If you like the ride height of the car is it is now, with the old shocks, then the odds are in your favor if you take those same springs and put them on the KYB's. You might get an extra 1/4 to 1/2" inch. I'm sure that they're the same internal pressure as the KYB's we use on the 280Z's. We get a little pop from the gas struts too. Not 2" though. Yes, Ill swap them over when I get a chance. The Starsky an Hutch look on a ZX isnt becoming. Link to comment https://www.classiczcars.com/forums/topic/60144-280zx-rear-struts/#findComment-550528 Share on other sites More sharing options...
