DC871F Posted June 5, 2018 Share #1 Posted June 5, 2018 So I ordered new shock struts, all 4. They are KYB Gas A Just. Long story short, the rear end sits about 2 inches too high, the ride is very harsh. So I contacted KYB and ask them to research the part number with them telling me I had the correct part. I went back and forth with them saying that something is not right, but there was nothing else they could offer me to help solve the problem. I drover the car around for a few months thinking they may settle, but nothing changed. Has anyone had a similar issue? Link to comment Share on other sites More sharing options...
Zed Head Posted June 5, 2018 Share #2 Posted June 5, 2018 What are the part numbers and what is the car? The 280ZX does not have struts in the back. It has what's called a trailing arm suspension design. Link to comment Share on other sites More sharing options...
DC871F Posted June 5, 2018 Author Share #3 Posted June 5, 2018 2 hours ago, Zed Head said: What are the part numbers and what is the car? The 280ZX does not have struts in the back. It has what's called a trailing arm suspension design. 82' NA. KYB KG9113 Gas-A-Just Link to comment Share on other sites More sharing options...
Zed Head Posted June 5, 2018 Share #4 Posted June 5, 2018 Just trying to help. Sorry, didn't really have a good picture of the ZX rear suspension. I guess it is a strut, by strict definition. Rockauto says that's the correct part. I could ask a bunch more questions but I don't have a ZX anyway. Who installed them, did you mess with the springs, did it ride correctly before, do the new ones look like the old ones, etc. The basics would be to check that the shocks aren't bottomed out. The springs hold the car up, the shocks might only add 1/4" from the internal gas pressure. Good luck. Link to comment Share on other sites More sharing options...
DC871F Posted June 5, 2018 Author Share #5 Posted June 5, 2018 18 minutes ago, Zed Head said: Just trying to help. Sorry, didn't really have a good picture of the ZX rear suspension. I guess it is a strut, by strict definition. Rockauto says that's the correct part. I could ask a bunch more questions but I don't have a ZX anyway. Who installed them, did you mess with the springs, did it ride correctly before, do the new ones look like the old ones, etc. The basics would be to check that the shocks aren't bottomed out. The springs hold the car up, the shocks might only add 1/4" from the internal gas pressure. Good luck. I did all the work, everything is correct. It doesn't make sense that just changing out the shock makes the car sit higher in the rear. Looks like Starsky and Hutch Torino. So I installed an old set of worn out struts I had, and it sits back normal. Something ain't right. Link to comment Share on other sites More sharing options...
Zed Head Posted June 5, 2018 Share #6 Posted June 5, 2018 Did you examine the two parts, side-by-side? Check the spring perch, push the rod in to the shock body, all the way down? You can do it by hand or by putting your body weight on it. It's actually good exercise. You have the KYB's right there, right? Give it a stroke. Measure the distance to the spring perch. Link to comment Share on other sites More sharing options...
DC871F Posted June 6, 2018 Author Share #7 Posted June 6, 2018 6 hours ago, Zed Head said: Did you examine the two parts, side-by-side? Check the spring perch, push the rod in to the shock body, all the way down? You can do it by hand or by putting your body weight on it. It's actually good exercise. You have the KYB's right there, right? Give it a stroke. Measure the distance to the spring perch. All even, nothing out of place. Nothing to see. Just sits too high, and ride is very harsh. Link to comment Share on other sites More sharing options...
Zed Head Posted June 6, 2018 Share #8 Posted June 6, 2018 Why are the springs mounted? They should be on the old set of shocks that you reinstalled. It's looking like you just got some higher rate springs on your new KYB's. It's not the shocks it's the springs. Link to comment Share on other sites More sharing options...
DC871F Posted June 6, 2018 Author Share #9 Posted June 6, 2018 15 minutes ago, Zed Head said: Why are the springs mounted? They should be on the old set of shocks that you reinstalled. It's looking like you just got some higher rate springs on your new KYB's. It's not the shocks it's the springs. I had an old set lying around, put them on just to see if the car would lower. Dont have the spring compressor handy. You think those are higher rate? It seemed they were the same as the old ones. I'll recheck. Thanks. Link to comment Share on other sites More sharing options...
DC871F Posted June 6, 2018 Author Share #10 Posted June 6, 2018 21 minutes ago, Zed Head said: Why are the springs mounted? They should be on the old set of shocks that you reinstalled. It's looking like you just got some higher rate springs on your new KYB's. It's not the shocks it's the springs. Here's the ones I just put on, factory strut, dropped the rear of the car 2+ inches, rides normal. Dimensions are the same as the KYB sitting side by side. Link to comment Share on other sites More sharing options...
Zed Head Posted June 6, 2018 Share #11 Posted June 6, 2018 If you didn't use the same springs then you can't really say it's the shocks. If you like the ride height of the car is it is now, with the old shocks, then the odds are in your favor if you take those same springs and put them on the KYB's. You might get an extra 1/4 to 1/2" inch. I'm sure that they're the same internal pressure as the KYB's we use on the 280Z's. We get a little pop from the gas struts too. Not 2" though. Link to comment Share on other sites More sharing options...
DC871F Posted June 6, 2018 Author Share #12 Posted June 6, 2018 4 minutes ago, Zed Head said: If you didn't use the same springs then you can't really say it's the shocks. If you like the ride height of the car is it is now, with the old shocks, then the odds are in your favor if you take those same springs and put them on the KYB's. You might get an extra 1/4 to 1/2" inch. I'm sure that they're the same internal pressure as the KYB's we use on the 280Z's. We get a little pop from the gas struts too. Not 2" though. Yes, Ill swap them over when I get a chance. The Starsky an Hutch look on a ZX isnt becoming. Link to comment Share on other sites More sharing options...
