Posted June 7, 20186 yr comment_550589 Does anyone know where to purchase 1mm oversized valves for this head? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60155-n42-head-rebuild/ Share on other sites More sharing options...
June 7, 20186 yr comment_550596 1 mm oversize valves would not be a standard part. You'd need bigger valve seats also. Are you sure you can't just replace the valve seats and use standard size valves? Don't know what you're trying to do but your request is odd. Link to comment https://www.classiczcars.com/forums/topic/60155-n42-head-rebuild/#findComment-550596 Share on other sites More sharing options...
June 7, 20186 yr Author comment_550599 Hi Zed, yes the plan is to have the seat cut to fit the oversized valve. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/60155-n42-head-rebuild/#findComment-550599 Share on other sites More sharing options...
June 7, 20186 yr comment_550603 I'm going to guess that you'd need to have some made. The N42 has the biggest valves already, for that head design. The ZX heads have the same valve head sizes too. Link to comment https://www.classiczcars.com/forums/topic/60155-n42-head-rebuild/#findComment-550603 Share on other sites More sharing options...
June 7, 20186 yr comment_550616 I'm pretty sure the Z valves are shorter in length than the ZXs. Seems like Diseazed uses early Z valves on his cut P79 head.My machinists used Dodge Hemi vale seats on my E31 when I went to the bigger valves. My expirences/memory only. Link to comment https://www.classiczcars.com/forums/topic/60155-n42-head-rebuild/#findComment-550616 Share on other sites More sharing options...
June 8, 20186 yr comment_550643 https://www.rhdjapan.com/search/engine/nissan_fairlady-z_s30-l28-09-1975-07-1978/model/nissan_fairlady-z/car/nissan/brands/kameari/category/cylinder-head-and-valvetrain_valves I'm sure you can also contact an L-series engine specialist to get what you need... Link to comment https://www.classiczcars.com/forums/topic/60155-n42-head-rebuild/#findComment-550643 Share on other sites More sharing options...
