Posted June 10, 20186 yr comment_550762 Has anyone here tried these? I wanted to move my car outside for garage space to work on my other Z. Our humidity is high here Is the hard part. Honestly, it’s high in my garage too. http://carcapsule.com/16-outdoor-carcapsule/ Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/ Share on other sites More sharing options...
June 10, 20186 yr comment_550764 yea the humidity is still going to be a problem. I have a car parked out in one of those HF portable garages, keeps the leaves off, and the UV damage away but it gets VERY hot inside. I can see how moving air would help with the heat, but maybe the hot may actually be better, I doubt any water can condense out considering how hot it gets. Too bad there is not a cheap way to dry the air that gets pumped in. Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550764 Share on other sites More sharing options...
June 10, 20186 yr comment_550773 I bought a gun safe dehumidifier for the inside of my 240Z. Works very well. For some reason my 280 seals up a lot better and has never gotten the light moldy looking spots on the door cards. They are inside though but might be of use to your situation? Walmart, https://www.walmart.com/ip/Remington-Mini-Dehumidifier/15729968 Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550773 Share on other sites More sharing options...
June 10, 20186 yr Author comment_550775 On 6/10/2018 at 4:02 PM, siteunseen said: I bought a gun safe dehumidifier for the inside of my 240Z. Works very well. For some reason my 280 seals up a lot better and has never gotten the light moldy looking spots on the door cards. They are inside though but might be of use to your situation? Walmart, https://www.walmart.com/ip/Remington-Mini-Dehumidifier/15729968 I’m going to have to try that. I’ve been using the disposable damprid canisters. I was thinking of running a dehumidifier in my garage, but the second I open the overhead and the backdoor forget it. Maybe just run it overnight and off in the day. Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550775 Share on other sites More sharing options...
June 10, 20186 yr comment_550777 I turn mine on first thing in the morning, my big dehumidifier, that's when it's the highest in my garage. Then I have a timer set to come on every four hours and run for an hour when it's really humid. The biggest help for me was to stuff towels on the top of my garage doors. That's where my outside entry was coming from, and my dogs flap door which I keep adjusted now so it hits and sticks to the magnetic strip on the bottom. I'm learning! Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550777 Share on other sites More sharing options...
June 11, 20186 yr Author comment_550834 I think I'm going to get this: http://mdmshelters.com/docs/carpocket_assembly.pdf It zips fully up and is large enough that I can build a cheap PVC structure to hold It up better. I'll run my fullsize dehumidifier inside. Customer service said that the zipper may leak, so I'd I have to be careful with how I position it. The rest of it she said is waterproof. Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550834 Share on other sites More sharing options...
June 11, 20186 yr comment_550835 Any bag will blow around and scuff the paint outside. If you could use polyethylene vapour barrier and find an iron to melt it shut then install a vacuum port to a shopvac on a timer .... now your talking. Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550835 Share on other sites More sharing options...
June 11, 20186 yr comment_550836 Sounds like you need one of these: https://www.carcoon.com/ Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550836 Share on other sites More sharing options...
June 11, 20186 yr Author comment_550837 On 6/11/2018 at 7:53 PM, 240260280 said: Any bag will blow around and scuff the paint outside. If you could use polyethylene vapour barrier and find an iron to melt it shut then install a vacuum port to a shopvac on a timer .... now your talking. Yup I was thinking the same thing on the vacuum bag. My car is a primer queen at the moment. Not worried about paint to much. My issue is water, leaves, and all the other crap that gets into every crack and crevice. I can wash my daily and 10min later something has landed on it. I’ve got a lot of oaks around. Edited June 12, 20186 yr by JSM Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550837 Share on other sites More sharing options...
June 11, 20186 yr Author comment_550838 On 6/11/2018 at 8:46 PM, rturbo 930 said: Sounds like you need one of these: https://www.carcoon.com/ Ideally a vacuum bag would be the best. That one is like the first one, but thanks. Saw that earlier today, but thanks. Both I think pump hummidty here. Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550838 Share on other sites More sharing options...
June 11, 20186 yr comment_550845 You could get a welding tank full of Nitrogen and fill it with that, no humidity, no oxygen to react and age it. It would be in stasis, preserved for eons. Edited June 11, 20186 yr by grannyknot Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550845 Share on other sites More sharing options...
June 12, 20186 yr comment_550858 Fill it with nitrous oxide and I'd live in there, polishing between giggles and the choo choo train. 8^) Link to comment https://www.classiczcars.com/forums/topic/60173-carcapsule/#findComment-550858 Share on other sites More sharing options...
