Don't gouge the bearing seat sides when you're driving the old races out.  It's easy to do (for me anyway.  Unless the PO did it.  Yeah, that's it...he did it ).  I got some small pieces of brass and aluminum rod to be sure.  There's a cut out in the seat to give access to the race.  Probably covered in grease so you won't see it.
14 hours ago, gotham22 said:
Site unseen do you have the link by any chance
Of course I do.  My  #1 mechanic with a camera. @240260280
http://atlanticz.ca/zclub/techtips/frontwheelbearings/index.html
Rears here...
http://atlanticz.ca/zclub/techtips/rearwheelbearings/index.html
Everything else...
Edited by siteunseen
16 hours ago, gotham22 said:
getting more done.  Next moving on to the wheel hub bearings and rotors
Enjoy this: http://240260280.com/Tech/General/Front Axle & Suspension/Wheel Bearing/index.html
@siteunseen ?
One question, the brake piston was freezed and I needed to use a grease gun to push them out.  Now that they are out how do I clean the grease inside the caliper
got it, the solvent should clear the inner passage ways right?  The projects that should be easy are always the worst.  I received some goodies yesterday - KYB shocks, Eibach springs and new rotors
I was in a similar situation, but not quite as bad.  That said, I have not found someone willing to do the work (Daytona Beach, FL).  That said, I kept looking for a car with no rust.  I was lucky and found one in Miami.  The rest of the car is not that great, but no rust was my only criteria.  Now I'll take all of the good stuff off of the rusty car and put it in the solid car. The pics below aren't as bad as yours, but still needs attention.
If there is anyone in Orlando/Daytona Beach area that can fix this please let me know.
  • 3 weeks later...
Steady progress is being made.  The grease popped the stuck caliper pistons nicely.  However, it then clogged up the inner passage ways.  After a lot of trial and error (air and various cleaners did nothing) I was able to put both pistons half way in and grip them so they wouldn't move then I used compressed air.  Few times like this and they finally unplugged.  Tested with carb cleaner multiple times and saw it come out the other side.  Looks like it is all good now.
Next I disassembled the hubs and removed the bearings and races. Lastly shocks and struts have been replaced and I bought new ball joints.  Front suspension is getting close.  I was so proud of myself when I finished the first shock and strut and then I realized I put on the rear springs.  Posting the picture of what it should NOT look like.
I know nothing here is too earth shattering but I can't believe I have gotten this far.  ''
