This is absurd, of course, but it sounded like a dry knock not a wet knock.  Check your damper/crank pulley.
I saw the rust title and the number of pages and can't really remember all of the details of this car and engine.  Might be worth writing up a new "state of the situation" post.
I did lash the valves before I put the engine back in but I will check again.
As Zed Head suggested - here is the current situation
All the structural damage has been professionally repaired.  Engine ran fine before removal.  I did a compression test and it looked good.
Engine Work done:
new fuel injectors
oil pan gasket
lashed valves
replaced EGR
new oil filter
rear main seal
pilot bushing
new master cylinder for clutch and brakes
Transmission:
clutch fork
pivot ball
throw out bearing
new fly wheel and clutch
Suspension:
full rebuild of front suspension
rebuild of brakes
new wheel bearings
new hubs
I can already tell you that the lash on most of your valves is too tight. The back side (non-lobe side) of the lobes should never be clean like that. That's a sign that the valves are never completely closing and the base circle is rubbing all the way around.
And valves that never close can make some strange noises sometimes. I can hope that it's as simple as that?
