I'd guess that's for your ignition to the coil when the car is running. It's bypassed when cranking to start. If your Z has been converted to electronic ignition then the resistor might not be there. Look next to your coil.
Chuck
9 minutes ago, Jarvo2 said:
No need for the ballast resistor without points. I pulled mine off and the engine runs great with a full 12v going to the plugs
Coil.  12 volts to the plugs won't even make a spark. :confused:  And with current flowing it won't be 12 volts.  Just saying...
I think he already realized his error though.
Slow day.
