June 18, 20195 yr comment_577895 Interesting. My 10/72 Z has the V3 modifications, but no fin or hood seal. It does have the "competition" hood scoop, that may have made the fin and seal unnecessary. Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-577895 Share on other sites More sharing options...
June 21, 20195 yr Author comment_578141 Cleaned then painted the inside of the fenders with POR-15, then a light undercoat. Installed and aligned fenders and side marker lights along with a few engine items. Here is a quick phone pic of the car along with my embarrassing garage stuff in the background. We're getting closer. I really need a larger place. Will pick up the hood and remaining body parts next week. Edited June 21, 20195 yr by motorman7 Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578141 Share on other sites More sharing options...
June 24, 20195 yr Author comment_578269 I was a little surprised to find that the stock headlights for the '73 are H4 style headlights. The old ones (aftermarket) on this car are Cibie H4's. I Found some Kioto H4's so I installed those. These are the 'new style' Kioto H4's as the original style had a more rounded face. Also got a few more tubes installed on the engine. Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578269 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578509 A little more progress. Finished off most of the electrical, added more engine plumbing, installed glove box and partial radio. Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578509 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578561 Got the air cleaner back from Powder coating. Installed loosely just to see how everything looks. Meant to comment on the wires above. I thought that I would need to make a new radio and antenna harness after pulling these two cables off of the dash harness. I lucked out however, as these were the cables that were the original radio leads. Somewhere out there is an original radio with the cables cut off. The new OEM radio just plugged right in making things easy. Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578561 Share on other sites More sharing options...
June 28, 20195 yr comment_578568 Gorgeous!!  Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578568 Share on other sites More sharing options...
July 1, 20195 yr Author comment_578766 Wife was out of town this weekend so got a ton of stuff done. Also had @jayhawk and his brother stop by and provide support. Got almost all of the engine plumbing in, radio,  heater panel along with horns, engine light and a number of other items. Put in the battery and the electrical is in great shape. All of the running lights are working, radio and antenna work well (Andy and I even listened to a bit of AM talk show radio), interior lights and vent control panel lights are working nice. The LEDs work great on the dash, but not sure if they are truly adjustable. Will check this when it is darker. Overall, pretty happy with the progress. Pushing to get this looking nice for the Branson show. Alternator and last of the body parts will be coming in this week.  Also put in oil and water. Engine turned over nicely and we have spark. After I double check all the brake line connections and put in fluid, we will put some fuel in her and see how she does. We are getting pretty close. Latest pics are below. Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578766 Share on other sites More sharing options...
July 1, 20195 yr comment_578767 Man, this just keeps looking better and better. Really admire your work Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578767 Share on other sites More sharing options...
July 1, 20195 yr comment_578769 It looks great. Led's are not so easy to dimm. Not with the original turn resistance they keep on down to a certain voltage and then turn off . I think you need a pwm. Edited July 1, 20195 yr by munters Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578769 Share on other sites More sharing options...
July 1, 20195 yr comment_578820 Yeaaaaa! the radio works!!!! (Oh, yeah, and that other stuff too...:-) Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-578820 Share on other sites More sharing options...
July 5, 20195 yr Author Popular Post comment_579081 She's alive! Not sure if this video will download but will give it a try. Looks like I have an exhaust leak at the mainfold/downpipe interface. Otherwise, not bad out of the gate with minimal adjustments so far. Surprisingly , the only leak( so far) was the return fuel line near the gas tank. 20190705_135059.mp4 Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-579081 Share on other sites More sharing options...
July 8, 20195 yr Author comment_579186 Very close to finishing here. Got the clutch and brakes bled today. Also installed the final body panels. Just a few more details to finish up and she will be good to go. It's the mad scramble before ZCON in Branson. Right now we are in pretty good shape. Here are the latest pics. The body pics still do not show up well. The paint job is pretty amazing. Link to comment https://www.classiczcars.com/forums/topic/60309-were-bringin-back-the-flat-tops/?&page=43#findComment-579186 Share on other sites More sharing options...
