MM569457 Posted September 3, 2018 Author Share #13 Posted September 3, 2018 (edited) Started today dropping the gas tank. I decided the garage needed to be accessible first so I did some spring cleaning. I jacked the car up and worked on removing the bolt straps keeping the gas tank in place. I’ve read people being able to do this task in 15 minutes, overall it took me 4 hours due to stubborn bolts, hoses, and clamps. I had to take a few breaks due to the varnish gas giving me headaches. Some of you guys may give advice on the gas tank. Obviously I’m getting a new sending unit due to the corrosion. This tank looks worse than others I’ve seen online in forums. the punch bowl was adhoc, my gas can was too tall to fit under the car. Edited September 4, 2018 by Mike mcdade Link to comment Share on other sites More sharing options...
grannyknot Posted September 3, 2018 Share #14 Posted September 3, 2018 I'm not sure that sending unit for a 77 is still available, a few of us here have save ours by letting it sit over night in CLR, comes out very clean and working (that is if it was working before) Link to comment Share on other sites More sharing options...
Mark Maras Posted September 4, 2018 Share #15 Posted September 4, 2018 Ditto on the CLR. I had one that took a 48 hour soak to get it clean. Worked perfect afterwards. Link to comment Share on other sites More sharing options...
MM569457 Posted September 4, 2018 Author Share #16 Posted September 4, 2018 Then I’ll give it a try Link to comment Share on other sites More sharing options...
gwri8 Posted September 4, 2018 Share #17 Posted September 4, 2018 Punch Bowl for gasoline = 1 pissed off wife. ? Another vote for the CLR method that Whee introduced. I've got a tank soaking with about 3 gallons of vinegar right now. A very slow method but very economical and not as harsh as Muratic Acid. Seems to be working but my patience is wearing out. 1 Link to comment Share on other sites More sharing options...
MM569457 Posted September 4, 2018 Author Share #18 Posted September 4, 2018 Yea punch bowl is my mother’s. She has since passed away and I actually grabbed it from the rubbish outside. That is after a 3 gallon bucket filled up. Link to comment Share on other sites More sharing options...
MM569457 Posted September 10, 2018 Author Share #19 Posted September 10, 2018 I plan on installing 16x8 MST wheels with 0 offset and 4.5 backspacing. Link to comment Share on other sites More sharing options...
MM569457 Posted October 18, 2018 Author Share #20 Posted October 18, 2018 Trying to remove the half shafts from the rear differential, did not expect this to be much of a chore. Decided to liberally spray all the bolts with WD40 and try again tomorow. Sending unit has been sitting in CLR for a few days, about to scrub it down again. Link to comment Share on other sites More sharing options...
wheee! Posted October 18, 2018 Share #21 Posted October 18, 2018 Nice! I'm glad to see the CLR method making the rounds. It's very hard to find replacement sending units on the 280's. Link to comment Share on other sites More sharing options...
MM569457 Posted October 18, 2018 Author Share #22 Posted October 18, 2018 Debating. I want to have this car running again by spring, but fighting the differential is taking time. Me thinks I may keep the differential in, and proceed to brakes, wheels, and engine/trans install and make the differential job for next summer. Link to comment Share on other sites More sharing options...
Zed Head Posted October 18, 2018 Share #23 Posted October 18, 2018 If you're going to do wheels and brakes, and suspension, you might consider dropping everything as an assembly. Struts, control arms, axles, diff will all drop as one sub-assembly. Drag it out and the nuts and bolts will be easier to get to. 1 Link to comment Share on other sites More sharing options...
MM569457 Posted October 26, 2018 Author Share #24 Posted October 26, 2018 Control arms are out. Removing the rear diff crossmember the suspension sway bar gave way. Gave me bit of a fright. More repair work. Link to comment Share on other sites More sharing options...
