Fidanza's web site is pretty poor, the search engine doesn't find anything, but Google did.
Here's an example of a replacement plate.  Not sure if it's right for yours or not.  Probably best to call them.
https://www.fidanza.com/products/copy-of-flywheel-friction-kit-229501?variant=14995559841835
  On 6/3/2022 at 7:20 PM, siteunseen said:
I wonder if it's possible to flip it over and use the other side? It may be fresh and useable?
I’ll take a look. I wouldn’t be surprised if the bolts didn’t line up.
Heard back from fidanza. They have a replacement friction plate I can purchase.
new engine mounts came in, one wasn’t a perfect fit so I can to do a mod. Now I need to fund beer, pizza, and friends to bring the engine over, assemble the transmission, and drop it in.
  On 6/12/2022 at 4:07 AM, Yarb said:
Did you order factory Nissan mounts. If not it’s a known issue that the aftermarket dowels don’t line up.
They were aftermarket from zcarsource.
  • 3 weeks later...
Engineering type nerd talk but I took a GDT course long ago and Fidanza's concept makes me nervous.  Stacked error (wrong term, can't remember, probably stacked tolerances).  Are you supposed to have that plate skimmed before usage or just bolt it up and go?  Make sure that you understand well how it's supposed to be used.  Even if Fidanza is confident it wouldn't hurt to have it checked.
Edited by Zed Head
