Been driving for about a week now. I notice when I park and kill the engine, as soon as a lift my foot off the brake pedal I hear a deep “thud” coming from the back of the car.
any idea what could be causing it?
Does it still have drum brakes?
I'd see if the noise is from the brake system alone or if it has something to do with the suspension being loaded.  In other words, does it make the same noise if you press the brake and lift your foot, stopped, over and over again?  Or does it only make the noise when you've rolled to a stop with the brakes on.
Probably the second.  Which implies that something in the rear has a load on it, that is released when you let the brakes off.  First thought is the top of the strut in the tower.  Or a sway bar, or a control arm bushing.  That's three thoughts, but they're in order.
I'd have a friend watch the rear wheels while you put the car in reverse and forward and move back and forth.  Hit the brake a few times.  Something will show.
Edited by Zed Head
+ ed...eeeww
  • 4 weeks later...
I'll get back to checking it out. Currently out of country. Car is under stored under a car cover with battery disconnected. I was told it could be a mini-misfire.
