May 21, 20231 yr Author comment_653776 Been driving for about a week now. I notice when I park and kill the engine, as soon as a lift my foot off the brake pedal I hear a deep “thud” coming from the back of the car. any idea what could be causing it? Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653776 Share on other sites More sharing options...
May 21, 20231 yr comment_653777 Put it on Jack stands, grab a buddy and start investigating. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653777 Share on other sites More sharing options...
May 24, 20231 yr comment_653842 On 5/21/2023 at 2:09 PM, MM569457 said: Been driving for about a week now. I notice when I park and kill the engine, as soon as a lift my foot off the brake pedal I hear a deep “thud” coming from the back of the car. any idea what could be causing it? Does it still have drum brakes? Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653842 Share on other sites More sharing options...
May 24, 20231 yr Author comment_653851 Yes it does. They’ve been rebuilt. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653851 Share on other sites More sharing options...
May 24, 20231 yr comment_653854 Have you had a chance to get it up in the air? Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653854 Share on other sites More sharing options...
May 24, 20231 yr comment_653856 3 hours ago, MM569457 said: Yes it does. They’ve been rebuilt. You might look at the rear brakes, the diff, and the half shaft u-joints. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653856 Share on other sites More sharing options...
May 24, 20231 yr comment_653858 I haven’t looked way back in thread is this an auto or manual car? Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653858 Share on other sites More sharing options...
May 25, 20231 yr Author comment_653876 Manual. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653876 Share on other sites More sharing options...
May 25, 20231 yr comment_653878 On 5/21/2023 at 2:09 PM, MM569457 said: when I park and kill the engine, as soon as a lift my foot off the brake pedal I hear a deep “thud” coming from the back of the car. I'd see if the noise is from the brake system alone or if it has something to do with the suspension being loaded. In other words, does it make the same noise if you press the brake and lift your foot, stopped, over and over again? Or does it only make the noise when you've rolled to a stop with the brakes on. Probably the second. Which implies that something in the rear has a load on it, that is released when you let the brakes off. First thought is the top of the strut in the tower. Or a sway bar, or a control arm bushing. That's three thoughts, but they're in order. I'd have a friend watch the rear wheels while you put the car in reverse and forward and move back and forth. Hit the brake a few times. Something will show. Edited May 25, 20231 yr by Zed Head + ed...eeeww Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653878 Share on other sites More sharing options...
May 25, 20231 yr Author comment_653879 You mention sway bar…. The mounting brackets broke and we removed it. Wonder if that’s the culprit Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653879 Share on other sites More sharing options...
May 25, 20231 yr comment_653881 I wouldn’t think that would be an issue. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-653881 Share on other sites More sharing options...
June 19, 20231 yr Author comment_654361 I'll get back to checking it out. Currently out of country. Car is under stored under a car cover with battery disconnected. I was told it could be a mini-misfire. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=26#findComment-654361 Share on other sites More sharing options...
