Size, Length, Pitch air conditioning compressor bracket bolts
Dude
Where is your compressor mounted? If it's the monster York thing on the right side that surrounds the fuel pump, then all the engine threaded holes on that side are M8x1.25. If its mounted down low on the header side, those four threaded bosses on the block low down are M10x1.5mm    As to length, get your tape measure out....
Thank you zKars  yes it was the four bolts on the block that were 10×1.5 mm   As for the length it came out to be 7/8 of an inch I just have to find  bolts that short that a 10.9 strength Metric now ???
zKars  I saw an older post where you had installed the GEN two mini I was wondering if you had pictures of the brackets you use to mount the unit under the dashboard and if so what metal used and where I could purchase that metal ?
  • Who's Online   1 Member, 1 Anonymous, 832 Guests (See full list)
