Hi,
My plastic choke cable sheath is broken. The cable inside is fine.  Does anyone have any suggestions for alternative replacement sheath?
All the Z car parts houses sell cable and sheath together which I don’t need (and is expensive). Thank you.
Howard
1974 260z
If the cable works okay and you are trying to make the look better and sealed from water. You can use a long piece of black shrink rap and cover it.
72 body with 71 interior, Eibach, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Zstory, SUs, BRE Libre wheels and front spoiler.
